My First Kart: Nitrous + 358cc = PAIN #2
Ibnzmonkey
Keep Austin Weird
Austin Tx
Ibnzmonkey
Keep Austin Weird
Austin Tx
Took apart the kart for painting/ Final assembly.
got tired of the black chassis so i gave it a shot of Banner Red from Krylon.
BradenM
Etre Et Durer.
In a big jar of Nutella, nom nom nom
Nitrous is safe when you understand all of the working principles involved, understand that you need to spray it in with an appropriately sized jet, understand what it does and why, e.t.c.
It ISN'T safe when you just bolt it on and go, like on the fast and the furious.
There is a lot involved.
thatcobaltguy
I have nitrous on my drag car. I was just wondering if it was safe on a briggs flat head with a billet 110 cam over sized valves arc rod wiseco piston. billet flywheel. billet head. and a tilly alky carb. with alot of machine work. I was told it would generate 15 hp. could I run a 5 hp shot on this.
jr dragster T
Cold place
Sure you could, For that matter you could do that to a stock briggs you just have to know how to set it up properly and when to say no.
Ibnzmonkey
Keep Austin Weird
Austin Tx
Where is nitrous video? PLEAAAAAAAAAAASE! KTHXBI
Um, im still building the kart. When im TOTALLY done with it i will post up vids. Right now Im the the Final Assembly stage. fixing bugs, setting up the perfect steering angle, Toe-in, Caster/Camber, Fueling, Control cables, etc...
