Has anyone got any ideas about the carb insulaters i posted above?
I've gotta ask
What the hell is a carb insulator
The first two pics look like a spacer
The second pic is maybe a gasket but looks completely different
The last pic is a standard gasket
I got my head and new adaptor back last night.
This weekend I will hopefully be able to get close to finishing this baby![]()
n' time :toetap05: I hope no one was holding their breath Wait, you mean it took him 4 months to make the first one & 4 days to do it again![]()
as for the valve cover
quite the oppersite
it must be free to breath without restriction into the air box
Paul- Are you planning on using the governor? I think you're going to have trouble with it. I see that you are missing the long thin spring that runs in concert with the long rod that goes to the carb, and the tension applied is pretty important!
Post #129, middle pic, long rod. There is a long, fine spring that wraps around that rod, and connects to the governor arm, and to that really small hole on the throttle arm on the carb.
yep thats the spring (#16)
u should have removed the governer duirng disassembly
