my 4x4 two cylinder turbo'd cart build
Clayton
Saskatchewan, Canada
with the governor off the engine it really winds up though , just havin a little trouble with the idle . it has to idle kinda high or it will bog down and die out, my guess is its still getting too much air and not enough fuel?? ive had to restrict the airflow into the carb quite a bit so far
I don't know alot about 2 cylinder engines but when that happens to my hondas I either turn the carb needle out to allow more fuel, or I drill out the main jet, and sometimes the idle jet. I am sure someone can tell you exactly what yo otta do.
mudduck7.3
iowa
picked up a winch for it tonight , i might go to the shop to mount it tonight , if i do ill bring the camera
mudduck7.3
iowa
haven't got a lot of progress done in the last couple days . im puttin a ford steering box on it from a early 80's f150 its 4 turns crank to crank. haven't mounted the winch yet either . gonna try to work on it tonight and get some pics
mudduck7.3
iowa
been busy with work and the kid. but i managed to get the motor running right , took the carb apart and cleaned everything . runs perfect now. i need to get back to work on it though , the new steering box is mounted just need to get some more heim joints for the steering draglink then put the clutch on and take it out for the first ride hope to have some pics up of progress within the next couple days
mudduck7.3
iowa
got a little work done last night . mounted and wired the winch and boxed in the tabs for the radius arms. you can also see the steering box is mounted behind the winch.
jim454
Why don't you use a 350 chevy with Aluminum head's and intake you would definitetly have enough power to turn those axles.Just make sure you have a good roll bar and safety equipment when you make a test run.Is that a Corvette body?Nice job so-far,you are all over it!!!
mudduck7.3
iowa
ill triangulate the frame where needed to beef it up some. and im a ford guy , no way no how a single chevy part will ever find its way onto a build of mine haha. and no the body don't count its in no way made by gm. but yes its a stingray body
bighead
Pacific Northwest USA
55% the drive chain will break.
35% the mower transmission explodes
10% it works fine.
Thats just from a fence sitter. Your skills are way beyound mine so just brush what I think off your shoulder friend. You know how the fence sitter Monday morning quarterbacks are right?
mudduck7.3
iowa
its all possibility although i don't think my #60 chain will break , its huge. but they're just parts, i can always make something bigger
getitdone
I've been thinking about something along these lines for a while now.. although i was gonna go 18-24hp, 22 or 25 inch wide atv tires, and lockable diffs off of a side by side.. oh not to mention selectable steering! Do you think that'd be excessive? :D
You've seen this build. Do YOU think your plan's excessive?:roflol:
mudduck7.3
iowa
went and picked up some more heims today for the steering and built the linkage . she steers very easily now with the 4:1 ford box. im not going to hook up a pump to it right now because i won't need it but when my son is old enough to drive it i will be putting a pump on it so he doesn't have a hard time. ive been tossing around some ideas for the roll cage and how i could make it so its still easy to get in and out of with the cage on . i think im gonna just make a cage with a flat plate on the top on hinges as a hatch and get in from the top of the cage.
i got a new set of warn hubs to put on the d44 front, i need to order my enforcer clutch , bunch of random bolts and put fluids in the axles and she's ready to take for the first cruise around the shop . i also have a friend thats going to take care of the fiberglass work on the body then ill build some more mounts for it . im startin to get excited for the first ride though.:thumbsup:
mudduck7.3
iowa
get to it!! id love to see more builds like this out there . seein new ways to 4 wheel is just awesome .
TheMancoMonkey
ummmm all i have to say is that is some heavy gearing for a tiny motor like that but you are going offroad so you you wont be doing like thirty. Please prove us wrong if you do its gonna be badass
mudduck7.3
iowa
gearing can always be changed if need be , but thanks! we will see soon enough
