my 4x4 two cylinder turbo'd cart build
B man
Tecumseh FTW!
Oliver springs,Tn
lets do a little comparison shall we?
Before complete loss of mind.& After complete loss of mind.
mudduck7.3
iowa
there is a lot of difference there for sure! i actually took a set of 36x 12.50x15 super swampers ( pretty much the same tread pattern as the 44's on there now) off one of my other trucks because i was selling them so i was gonna take a few pics with them on there , i figured they would be about the perfect size . but i never bolted them on there and the guy came to buy them earlier than expected so ill have to wait till i buy another set of tires around that size.
mudduck7.3
iowa
got the front axle tore down , putting new axle joints in because the old ones are so dry and rusted up that its dragging the steering down a little , also startin to put some of the random bolts in and gear oil in the axles , ill get some pics later
mudduck7.3
iowa
old crappy axle joints
new joints
new lockouts installed
bolts in diff cover and both axles full of oil
shinny new air filter
mudduck7.3
iowa
Man... hurry up with some videos! :D
Cant wait to see what happens!
i might take a video of it runnin tonight but i still need to get the carb off and get the jets cleaned out it runs and idles pretty smooth but loads up when it idles for awhile and backfires some. just waitin on the clutch before i have a video of it drivin though , think im gonna order it tomarrow.
mudduck7.3
iowa
Put the dualies back on and shoot a vid!
i still have to groove the other 4 tires and make the dualie adapters , they were never actually mounted just sitting next to the first set of four. but as soon as its mobile i will definitley get them grooved and mounted and have a video up of it playin in the creek!
mudduck7.3
iowa
do you have the engine cover? it may not be cooling enough.
yea i do still have it . i was discussin that at the shop the other day with a friend , he suggested to put it back on so it would force some of that air down to the rest of the motor, im gonna put it back on but i gotta modify the cover to work around some parts ive added
mudduck7.3
iowa
i found the memory card for my video camera today so i got some videos of it runnin, i know the video quality is crap but its better than nothin . from the videos you can hear what its doin , my vote is the carb but im open to opinions.
oldbikerarlo
Old guy
Marana, Az.
My lawn tractor with the same engine was doing the same thing, It had a leak between the fuel pump and float bowl, and the diaphram was real stiff. I installed a carb kit and it runs better than it did brand new.
