ultralight01
Senior Yet Young Member
I took a picture of the valve cover off. The push rods are not connected to the arm thingies. I don't think I need to loosen them to attach them again.
---------- Post added at 09:02 AM ---------- Previous post was at 08:58 AM ----------
Hey, thank you, random website, for the explanation...
"A push rod is a component of the valve train of certain piston engines. its function is essentially to push the valve open.Rods used in an Over Head Valve engine to open and close the valves. They are moved by the cam and are about 8" long with a diameter of around 1/4". One end is pushed up by the cam and the other end makes contact with the rocker arms which rotates and pushes the valve open."
I'll do some work for a while... Post later.
You can't give up. I'm sure there's hundreds of Murray kart threads on here (I'm new) but yours is the one I'm following since it's all fresh and new and relevant. Don't know anything about these karts; seen a few around, but from my experience Murray makes only lawnmowers and bicycles so this is my familiarization with 'em.
Forge on ahead, young grasshopper!![]()
JK, I only joke... I do not condone fraudulent returns to HF.
Its a little late for that line! BOB!!! :toetap05:
I can go back in time and fix that.
At one fell swoop!
