Bluethunder3320
- Messages
- 5,677
- Reaction score
- 37
nice. and awesome mini bike!
Looking Good Frey. I know it can be impatient to not weld everything as you go along but its the best way to build a project to keep it from shrinking and tweaking. Are you using a chopsaw to cut the material? If so you can also use the chopsaw blade to clean and chamfer the edge of the tubing after being cut. Just grab the tubing and hold it against the side wall of the blade and turn the tubing around on the side of the blade. Saves a lil time then having to use the angle grinder. Just be cautious and don't push to hard against the blade, if its a cheap blade it could break and send blade material flying at high speeds.
No body said Fabbing was easy and or not dangerous. Always be safe and wear gloves even if they are heavy duty latex gloves, not the thin cheap ones. I use the blue textured ones from Harbor freight. Also glasses or face sheild. Good luck. I hope to start my mini buggy build this year.
. If I were to use the sled engine I wouldnt have enough room for the driven which is kind of a problem. Let me know what you guys think.
so I will be making a trip to discount steel this weekend to get the steel for bracing my frame ant the roll cage
I'm not the expert here, but should you not weld the kart up properly as you were going along, instead of spot welding it all together first. I know that warping might be a problem when you get around to welding it all up now.
As I said... I am not an expert, just asking. Nice looking frame though. Good work.
Yup Messy Stuff them CV's.
Along with warping from fully welding, tacking also makes it easier to remove or relocate bars that are in wrong position or the need to be modified. Sometimes you don't realize that certain tubing needs to be relocated until its partially put together.
. I havn't really been working on the buggyas much as Id like because of freestyle and baseball. I should be CNC ing out my suspension components on mondat or tuesday. I was searching for a moter and I think ive finally found one. Its a 2005 gsxxr 600 fuel injected motor for only $300
