Making garage more hospitable towards tools and projects?
jr dragster T
Cold place
oh yeah and usually the walls in a house are not insulated anyway
Maybe down there where you live, If you had no insultation out here in Canada you would freeze to death. -35 to -40 winters and summer goes up to + 35 to +40
Flexibel_kampfe
Hopeful for building kart
RI
LOL!
And Freakboy, yea, wiping blood off is a plus... I cannot tell you how many times I have left my hand on the table, while going to see something under the table, and when I looked up, it was within millimetres of the blade.... opps...
freakboy
the names 'mater
hick town
LOL!
I tend to keep my body parts away from moving items... especialy when im using a bench grinder on a really low waist high bench... or using a lathe when its about waist high....
Flexibel_kampfe
RI
Lol, what, dont want a free sex-change? lol.
Rustydog2010
NZ Nutta :|
New Zealand
Yea, we live about 400 meters from the see on top of a hill, so everything we have rusts like buggery. And considering there is some pricey gear in the shed; like the mill, lathe and drill press we have found that using used engine oil applied with a brush works perfect.
Flexibel_kampfe
RI
That would work if I were doing primarily metal work. But oil is a bugger to clean off wood, unless you specificly want black wood... or maybe that sounds too much like buggery... lol
fowler
Bullsbrook West Aus
same boat as rusty but we dont seem to have the problem can u wax the band saw each day
and cut a big bit of wood each day as at school the band saw is never rusty i guess it is cause it is used so ofen
Flexibel_kampfe
RI
I finally got the go ahead to insulate the garage. So thats my first step. I would like to find out from you guys the best, CHEAP way of doing it. Thanks. (Rust-oleum epoxy paint, but unsure for insulatin.)
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
This is a concrete wall your talking about, right? read this. Insulating alone wont do anything to prevent/slow rust. Since part of the garage is below the ground line, I'd suggest sealing the wall with something like this.
Flexibel_kampfe
RI
That stuff looks good, but expensive, for the coverage. I would need like 3 gallons(20something X 10 X 8)
Flexibel_kampfe
RI
O, that makes sense.:p
Lol....
Question tho, does that stuff insulate from heat/cold, or just moisture. Because not only do I want rid of moisture, but I want rid of the cold in the winter... its no fun, and downright bloody dangerous to work with gloves and a winter coat...
newrider3
Colorado
The sealer is to keep out the moisture which seeps through the concrete, you would then use foam-board type insulation over top of that.
redsox985
PA
My neighbor jimmy rigged some insulation in his garage. First he painted with water blocking paint, it's partly underground. He put up studs (2x6's) and then laid in rolls of fiberglass insulation. He covered them with drywall and then put up pegboard. It's nice for tool organization.
Flexibel_kampfe
RI
Yea but *In Irish Accent* I forgot where me hid me pot of gold!
redsox985
PA
2x6's insulation some cheap sheetrock and pegboard. In Pittsburgh there's a place called Construction Junction that sells unused or salvaged materials for dirt. Packs of 25yr shingles are $4, doors are $10-20, tile $.05each. Look for places like this near you and build up supply over time. It's a great place to go if you can get past the volumes of hybrids in the parking lot.
