Thepartsguy
- Messages
- 1,436
- Reaction score
- 1,298
you see the notch in the Briggs gov arm that looks like it would hit the silver plate behind the blue air filter and act as a throttle stop? perfect! I have tons of adjustment left at the twist throttle also. full throw of the twist throttle. I have it working perfect but the spring is just slightly to tensioned still so high Rpms. I’ll make the spring a bit lighter and fine tune it today. it is a better setup then stock so I’ve been told.That looks like a better set up for a mini, then the factory "utility engine" throttle assembly.
With the engine off, how much twist do you get out of the grip from idle to WOT????
