Lo206 gearbox
Don't know what to tell ya. Maybe a quad engine. Then you have a built in transmission.
I just don't think a race purposed engine is gonna be ideal. Turning 6k just to putt around and drag a trailer.
Now if you just making a zoomie scooter that's different.
Leonardpursuit713
Yes 6k to build a scooter to putt around and drag a trailer. It’s not to go fast but I need the torque so 200ish cc is what I figure my sweet spot is. Add a gearbox and done. Easy install. Would still look “stock”
You can get the best named engines up there. Powerfist!. Lol
I'm sure it's the same as the predators we get down here.
Looks like you can get a 420 for less than a dollar a cc.
And i meant turning 6k.rpm
Leonardpursuit713
For instance powerfist makes a 212 cc but it has a fuel tank on top. How hard is it to relocate a different tank. And attach a gearbox
Atlanta, GA
The gearbox and torque converter you mentioned in the beginning will hook up to a Powerfist just as easily as the LO206, they are nearly identical in that regard. 3-4 bolts and the gas tank comes off. Longer fuel line and half a teaspoon of ingenuity and you're done.
