leaf blower rebuild, eventually to power little bicycle, fun!
r97
Measure twice cut once
Massachusetts, USA
i'm hoping to try and get one soon, but soon means like 4 months. its all i really need to make those things, but if i buy even e cheap one 'm pretty much broke, how are those hf ones? not my first choice but maybe, i might try craigs list.
Bluethunder3320
i saw a RYOBI one at home depot for 100 bucks. table top of course...
the HF one is always on sale
r97
Massachusetts, USA
yea my eyes are one that royobi, its got a cvt, brand name, and a few other features, i think tyler or some one owns one.
r97
Massachusetts, USA
same,along with some measuring tools, torque wrench and what ever else i can think of, of course thats the list, unfortunately i don't get every thing on the list. lol
p.s. jr dragster tyler. i'm going to bed! i got to climb tomorrow!
r97
Massachusetts, USA
oh ya i was thinking about it, and it prob cost me the same to make one of those sprocket clamps as it would to buy one, unless i made a sprocket from scratch
Bluethunder3320
ooh, thats right, i forgot.
id say 20 bucks isnt bad for the whole thing.
itd be pretty hard to make one without a press or lathe anyway becauuse remember you need it to be perfectly allighned and no wobble.
r97
Massachusetts, USA
remember? no clutch, direct drive! just gear it low so at idle it moves like 2mph, turn it off if i need to stop, and sprocket clamped directly to wheel so i can still use the pedals to assist the engine/start engine/use coaster brake. ill have a jack shaft in there some where, i will get my ratio once i figure out my rpm range.
Bluethunder3320
ooooh yeah, lol......
so for a jackshaft i suggest using the bearing block of an old bike (where the pedals are...) and attach a second sprocket or something.
and then you could mount it somewhere above the existing one on ur bike.
r97
Massachusetts, USA
i'm just gonna use two pieces 1x2 rectangular tubing i have, then drill a 1 3/8" hole in each, pop some bearings in em and i'm good. i got an old bike brake lever and cable, which is the perfect length for the bike. i'm gonna order the piston ring, and get fast shipping if its n ot too expensive. i'm also gonna buy(or make idk) a tachometer. then ill start on my ratio. today i want to hd and sears, yea i was looking at drill presses and air compressors for a while :D, you guys should have seen the snowblower i found!
Bluethunder3320
I need a snowblower, all i got is a shovel lol.
Could you get a chainsaw oiler worm gear for a tach?
I kno a site that sells cable tachs (i think cable)
Good luck with that jackshaft!
r97
Massachusetts, USA
i just need a tach for like 5 sec, i found a way to convert a calculator to sorta work as a tach. i re-used one of the old piston rings, hopefully i can get some new gas and oil tomorrow, lets hope it runs!
