Lawn-Boy Model 'E' Twins (mockup)
Rickracer
RM250 Race Kart Driver
Kissimmee Fl.
If you got two more of those megaphones and welded the big ends together, you'd have expansion chambers, I guarantee you would pick up some power and lose some noise. ;)
Kaptain Krunch
Pro Junk Collector
vermont
Holy Shnit that things got much better acceleration than i would ever imagine a centrifugal clutch could give.
Very cool.
Kaptain Krunch
Pro Junk Collector
vermont
They (clutches) don't ever get hot either...even with single engine.
Different story with drum brake. Gets almost too hot to touch.
Thanx.
I think i've said this before, but i have that same frame, well its not the same anymore, its 2ft longer and has a motorcycle engine in it (not done yet). Anyways, the drum brake got very hot in mine also, as did the clutch. What gear ratio are you running? and what kind of rpm do you think those lawnboys reach?
Russ2251
AZUSA:Powered by LAWN-BOY
17 tooth Noram clutch and 72 tooth driven which equates to 4.23:1. A bit steep, but does pretty well.
...what kind of rpm do you think those lawnboys reach?
Unknown. Tiny-tach indicates 5,852 rpm under load. I believe these engines to be capable of something more than that.
I do not wish to do irreversible mods to these power plants (such as porting), but am planning on replacing reed valves as suggested by Crazycart as posted in this thread starting with post #18.
jr dragster T
Cold place
Why would it not be a race? In the 1/8 mile your going to run out of gear pretty fast while my motor will still be pulling while the CVT clutch shifts.
Kaptain Krunch
Pro Junk Collector
vermont
No matter who wins, I get to take on the winner, :D :D :D
Then i'll take you when my karts done. Although yours is prolly faster anyways...
Russ,
I've heard lots of good things about the Noram clutches, the one i had was a very cheap comet. Paying more than $30 for a centrifugal clutch just didnt seem worth it to me.
I'm not sure if you've seen it before, but i used to have the link to a site where you could calculate the dimensions for an expansion pipe. It seemed fairly complicated, but i think it would be worth it.
Rickracer
Kissimmee Fl.
I just threw one together for my grandson's pocket bike from an old driveshaft I cut up, (yep, that looks about right, :D), and it made about an 8mph difference, even though I added a muffler to keep the neighborhood happy. ;) :cool:
If everything goes according to plan, I'll have it at the 1/8 mile dragstrip this coming Friday night, so I'll know just how quick it goes in a straight line. :cool:
Russ2251
I do not wish to use a CVT so it would not be a fair comparison. I prefer the old school approach.
All things being equal...you wouldn't stand a chance.
Out of the box, Lawn-boy's will outlast/outperform anything (equivalently sized) China has to offer.
Take a look at what it cost you to "soup up" your clone.
All I did was add a $30.00 NOS carb and remove head gasket for more compression and voila...clone killer.
