The small engine repair shop. That's was where he ended up waiting around for some guy that never showed!
I almost forgot... The Train P34 has 2 engines! Right?
I think I remember some "sunburst Yellow" wheels. Probably got painted OD green!!!
You sir, are hilarious!
Sunburst yellow, that's right!
Update:
Lots of work today starting with some sorting. Seeing SOMEONE seems to like those manco's... I did some switching around. Why? Because HE is right. The TonkaR/T really does need a set.
So, moving this & that around yields a nifty set of 5" fronts & 6" rear DIRT wheels. Suitable for... Every one of my rides.
How handy to have around.
Then it was onto the Tonka... With most things attached now and a few small things to do, we're nearing the end of this one too. (shut it chancer!)
The front clip was a pain to make because it only fits on if you take the steering wheel off... and that's just fine. This thing turned out well. The lines of the chrome/brass trim I used for it lined up beautifully with where things needed to sit.
Then, at the end, seeing I might not use them... except here, those hubcaps. Seeing I made them for the manco's anyway... and they're fricken Yellow... and they appear to be go powers. Might as well go with it. I told myself each one would have a special set... so...
Yea.
Check out what one of the tracks is used for! The dump bed NET! And I sooo love how the engine cover fits the air cleaner housing nearly perfect. Makes it easy and I don't have to make any special air cleaner appendages.
This thing is growing on me and has a certain stance. Thanks for naming it Sid. She's one of the ones that will live on. It just came together perfectly today.
