Is this Briggs any Good?
Kentucky Boy
Bowling Green, KY
Bought an old go kart with this 5hp Briggs flattie on it. Had no compression. Upon opening it up I saw it had thrown the rod. Everything else looks good. The base of the cylinder has a small gouge in it. Is this block any good? Does the piston go down that far during the stroke?
Kentucky Boy
Bowling Green, KY
The governor had been disabled externally but the parts remained inside. The governor arm was left free swinging. I can't tell if the governor failed first or the rod. The crank is gouged some by rod wear.
And here is what's left of the governor and the rod. Luckily it didn't punch through the block.
Carnage. I have another crank and rod for this already just sitting around. The piston is still good. Cam and valvetrain are still good, and I already have most of the gaskets.
Kentucky Boy
Bowling Green, KY
Been cleaning this old block up. It was nasty. The cooling fins on the cylinder were packed with dirt and grease. Still need to work on it some more. This motor has old points on it.
The inside is cleaning up nicely. Luckily no bad damage was done.
All the parts are laid out ready for a cleaning.
Kentucky Boy
Bowling Green, KY
It appears to be removable somehow. The seal area looks to be lappable. I've never worked on one with points. The model type code is 130202 001501 18111507. What year is this motor? Probably needs a new exhaust valve and seat.
The points look ok. Just a little dirty.
Kentucky Boy
Bowling Green, KY
It is 78111507. The numbers have paint built up in them. Nov 15, 1978.
Making good progress on this motor. Cleaning it up real nice. Can't decide if I should paint it or leave it bare metal.
Kentucky Boy
Bowling Green, KY
So I've noticed my springs are different heights. Guess I need new springs. This motor needs a new piston, rings, valves, springs, exhaust valve seat, rod, crank, head gasket, side over gasket, a carb rebuild and an air filter. I could probably buy two or three predators for the price of rebuilding this Briggs. At least the gas tank is rust free.
Edit: The springs are supposed to be different sizes.
Nosandwich
The REAL Poboy
WHITE SETTLEMENT
Ummmm...its a 5hp Briggs. Go to a local scrapyard and pick up a mower. They might even have a tiller (even better) and use the parts off it.
Or go to OfferUp and look for something with a 5hp Briggs.
If you PM me an address, I can send you a crank for shipping cost only.
Kentucky Boy
Bowling Green, KY
I'll be rolling through BG in July. I'll put a 5hp Briggs (1992) on the curb.
Ha ha thanks. I'll have to get a second job if I get any more.
In anticipation of a successful rebuild, I bought some Briggs decals. I know they're not 1978 emblems but they're cool and I think they'll look good on this piece.
You need this sticker so it is street legal.
Funny how it says Item 69730, which is a non-hemi predator 212cc. LOL
Kentucky Boy
Bowling Green, KY
Trying to decide what to do with the cylinder. I've read not to hone aluminum cylinders. I need a new piston and rings but don't know what size to get. Would it be ok with stock size or should I get an oversized one? Should I have it bored? Hone it and get a new stock sized piston and rings??
Get some feeler calipers and check the bore. If it's not round or has a big taper or hourglass shape, then you might not be able to save it.
You will need to measure it before ordering a piston and rings anyway.
Kentucky Boy
Bowling Green, KY
I may just put this one back together with a new rod, original piston and rings and see how it runs. I'm planning on just flipping the kart it came on to sell anyway.
Been putting this motor back together. Cleaned all the parts. Installed the new rod, new crank. Polished the piston a little and reused the rings. Here is my zip tie valve spring compressor. Works like a charm.
Lapped the valves and had to file some off the intake valve stem to get my lash correct. Almost ready for some paint.
Wound up putting a new exhaust valve in. While grinding to adjust valve lash I accidentally took off too much causing it to be too short. Got the new valve lapped in then set the lash correctly.
Put the new rod in. New main seals and a new side cover gasket. Tapped and plugged the governor hole.
Getting it all back together now. Painted the motor with high temp aluminum. Reinstalled the points and gapped them to 0.020. Gonna lap the flywheel and put it back on. I've painted it also.
Removed all the grease and paint from the gas tank and repainted it.
We'll see how it holds up.
The weather was perfect for painting yesterday. I was even able to get the starter cover stripped down, sanded and painted. Came out near perfect.
Closeup.
