If you put it on the shaft than you'd have a bit of chain that's turning all the time the engine's running, which could be worse as far as safety's concerned and you'd have a bit of chain that would wear out faster. Would be unique though. You could also over or under drive your clutch with different size sprockets if you want a higher or lower stall speed.
