idles perfect but cant touch gas pedal
kart bruiser
Leechburg,PA
nice try just tried it cause i was at autozone when your entry came in
just so frustrating to know it ran perfect before i replaced all electrical
does 50cc or 150cc have any difference on stock cdi or coil wire for that matter ?
they were both listed as ok for either and my motor started right up perfect just wont react to pedal without dying aaaaawwwwg
kart bruiser
Leechburg,PA
he picks up kart on sunday
my work is done all new electrical and starts fine so truly rest is up to him but me being duly sworn to repair everything i touch LOL i cant let it be
2SlickNick
American Minibikes @ FB
Mesa, AZ.
Did you get a cheapo CDI from ebay?
do you still have the stock CDI? It is a Dc cdi. And the ASW CDI's are really good ones. Try the stock one and see what happens.
kart bruiser
Leechburg,PA
i was thinking of putting the stock cdi and stock coil on but one is malfunctioning dont know which one replaced them at same time so am wondering will one make the other break or vice versa or can i plug and play till i get it right ? so to speak
kart bruiser
Leechburg,PA
could the valves be running strong shut it down for 3 and half months fix and repair electrical and upon startup valves be out enough to cause this issue?
firemanjim
Just kartin' around....
Houston Texas
Ehh, I doubt it. I think its electrical, not mechanical. Cdi's are purpose built. I bought a chinese "high performance " 2stroke cdi and it DID make my quad faster, as advertised. Only $20.... To my door.
As previously stated, try your old cdi.... It might actually fix the problem..... I hope anyway.....:thumbsup:
2SlickNick
Mesa, AZ.
Let me know once you put the stock cdi in.....
I can't reiterate enough you have a DC powered machine!
2SlickNick
Mesa, AZ.
FYI a DC powered machine is is already pretty much at the top if its game CDI wise.
All the ac powered CDI's are converting it to Dc to get more power.
kart bruiser
Leechburg,PA
well put new carb on and did exact same thing BUT when i started turning key to fil up float bowl it ran fine fgor just a couple seconds before and it was warmed up
is it possible that valves are ok for idle but even the slightest bit more they comingle gases and shutdown ?
2SlickNick
Mesa, AZ.
Are you even reading what we wrote?!?
Cdi???????
Did you put the stock one back in???:mad2:
This is too frustrating!I am done trying to help until you put the stock CDI back in. The we can go from there...........
n3480h
NW Iowa
:popcorn::popcorn::popcorn:
Wait! Are you guys telling us that valves don't actually GROW longer when an engine has been shutdown for 3 months??? Hunh - who'da thunk it.
Jim4626
just taking a guess but check the pickup. it sounds like the pickup cant keep up with the flywheel and produce spark at higher rpms
