ID This Engine Please
OneTimeUser
We Don't Rent Pigs
Texas
Seems little engines multiply like rabbits. I have a bunch now and can't remember where half of them even came from. This one for example.
It says OHC on the valve cover. I looked around a bit and learned that Honda and Subaru (at least) make an OHC engine.
Can anyone identify this one? I could find no manufacturer's markings.
Thanks in advance.
Staff Murderator
Subaru, EX line, one of the very few overhead cam (not OHV pushrod) engines. It has a timing chain. Quite desirable.
Show us the numbers on the block if you can
Edited to add (for reference):
EX Engine Models​
  • EX13 – 4.5 horsepower
  • EX17 – 6 horsepower
  • EX21 – 7 horsepower
  • EX27 – 9 horsepower
  • EX30 – 9.5 horsepower
  • EX35 – 12 horsepower
  • EX40 – 14 horsepower
  • EX21 EFI – 7 horsepower
  • EX27 All Season – 9 horsepower
OneTimeUser
We Don't Rent Pigs
Texas
I will. Thanks.
Now I'm gonna look around for specs and availability of performance parts. Got a new cart yesterday and am wondering what engine to put on it.
I've been very happy with my Tillotson electric start, but may install this OHC engine if it can be hotrodded to produce some power.
Staff Murderator
Kinda suspected, like 65Shelby says, they are too few and far between to have hot rod parts. A niche engine but I have no idea, truly. The OHC is the novelty. ;)
Should be able to rev more quickly minus the clunky pushrods and tappets.
I will. Thanks.
Does it have a cam up top under the rocker cover ? You could mill and port the head for more compression and better breathing. Like others have said, probably no aftermarket parts. Maybe advance the timing. Would it hold together at sustained higher rpm. Is it governed? If you have a yearning to hot rod a small engine, you need to stick with the modern cloned type stuff. Tilly, Ducar, Predator ect. The hot rod parts availability for those engines is almost limitless.
Staff Murderator
OTR, you have a mission. Remove the valve cover and observe, or you might just have a lowly pushrod engine with the wrong valve cover. Take pics. 📷📹🤳
OneTimeUser
We Don't Rent Pigs
Texas
Hellion,
I won't take it apart (got plenty of go cart stuff to do), but I will send case numbers and verify that its OHC. I can tell by looking at the particulars.
Now I want an OHC engine for my new (to me) Mudhed. If I can't find one I'll go with a Tilly.
65ShelbyClone
SoCal
I took pictures of mine when I had it apart to replace a piled-up rod.100_6343w.jpg
My memory was correct that the model is cast into the outside of the engine, apparently on the cylinder head of the EX27.
The cam only has a single lobe which really limits what can be done with profiles. Honda does the same thing.
65ShelbyClone
SoCal
Apparently there are were performance parts available for the EX21, at least in Australia. ARC even made a rod and flywheel for it. The KX21 is a factory performance version of the EX21 made specifically for kart racing. Interesting.
Staff Murderator
That’s a neat valve train, @65ShelbyClone Did not expect to see the pressed metal...cam followers. That just leads to more questions.
Thanks for the pics, OTU sucks now. I thought he was cool.
:roflol:
OneTimeUser
We Don't Rent Pigs
Texas
Sticks and stones, etc.
I've never heard of a single cam lug operating both valves. Gotta look into this.
I don't know if my EX is any good (or where it came from for that matter). It may end up on my log splitter.
