ID This Engine Please
OneTimeUser
We Don't Rent Pigs
Texas
Seems little engines multiply like rabbits. I have a bunch now and can't remember where half of them even came from. This one for example.
It says OHC on the valve cover. I looked around a bit and learned that Honda and Subaru (at least) make an OHC engine.
Can anyone identify this one? I could find no manufacturer's markings.
Thanks in advance.
Staff Murderator
Subaru, EX line, one of the very few overhead cam (not OHV pushrod) engines. It has a timing chain. Quite desirable.
Show us the numbers on the block if you can
Edited to add (for reference):
EX Engine Models​
  • EX13 – 4.5 horsepower
  • EX17 – 6 horsepower
  • EX21 – 7 horsepower
  • EX27 – 9 horsepower
  • EX30 – 9.5 horsepower
  • EX35 – 12 horsepower
  • EX40 – 14 horsepower
  • EX21 EFI – 7 horsepower
  • EX27 All Season – 9 horsepower
OneTimeUser
We Don't Rent Pigs
Texas
I will. Thanks.
Now I'm gonna look around for specs and availability of performance parts. Got a new cart yesterday and am wondering what engine to put on it.
I've been very happy with my Tillotson electric start, but may install this OHC engine if it can be hotrodded to produce some power.
65ShelbyClone
SoCal
I can't remember because it's been so long since I sold the EX27 I had, but the block might be marked with the model or displacement kinda like a Honda. They're nice engines, but have no aftermarket support.
Staff Murderator
Kinda suspected, like 65Shelby says, they are too few and far between to have hot rod parts. A niche engine but I have no idea, truly. The OHC is the novelty. ;)
Should be able to rev more quickly minus the clunky pushrods and tappets.
65ShelbyClone
SoCal
The cam has only one lobe (similar to Honda designs) that actuates both intake and exhaust valves. It's sintered steel and is integrated with the sprocket.
I will. Thanks.
Does it have a cam up top under the rocker cover ? You could mill and port the head for more compression and better breathing. Like others have said, probably no aftermarket parts. Maybe advance the timing. Would it hold together at sustained higher rpm. Is it governed? If you have a yearning to hot rod a small engine, you need to stick with the modern cloned type stuff. Tilly, Ducar, Predator ect. The hot rod parts availability for those engines is almost limitless.
Staff Murderator
OTR, you have a mission. Remove the valve cover and observe, or you might just have a lowly pushrod engine with the wrong valve cover. Take pics. 📷📹🤳
