KartFab
Wish me luck. I'm gunna need it. I have three junk engines. Two are the K series engines, one of which is not seized (pictured).
1) k series pictured ran on CNG and I'm just going to run it on normal gas. Compression in the two cylinders is 120/90 last time I checked.
2) the next k series was from a pressure washer and is seized. Was straight gas powered. Will rob parts if I need to.
3) other one has a shattered cam hear that grenaded the engine. It's a different series and has a completely different setup :-( will use this one to say "at least the first one isn't this bad".
