Honda GX620 Build
KartFab
Wish me luck. I'm gunna need it. I have three junk engines. Two are the K series engines, one of which is not seized (pictured).
1) k series pictured ran on CNG and I'm just going to run it on normal gas. Compression in the two cylinders is 120/90 last time I checked.
2) the next k series was from a pressure washer and is seized. Was straight gas powered. Will rob parts if I need to.
3) other one has a shattered cam hear that grenaded the engine. It's a different series and has a completely different setup :-( will use this one to say "at least the first one isn't this bad".
Kokamo
Azzkicker extraordinaire
Liberty Hill, Tx
Sweet man! What's the plan to use this on? I'm building a GX670 at the moment....pretty much stock except exhaust and lots of port work. Mine is planned for as small of a mini bike as I can fit it on!
~Joe
KartFab
Cylinders, Pistons, Head Cleaned
~Joe
I dont know yet. I have to see if it will be worth putting on something. I have a mini buggy I am hoping to put it on.
Wow so the filter area had an air filter, but for some reason there was an incredible amount of 'muck' that had en-trained through the carb somehow (this was originally nat gas powered). Really nasty stuff and you can see from the pictures how bad it was. It looked like it was getting build up prior to combustion? I really dont know. The intake valve was JACKED UP with CRUD.
I used razor blade to remove carbon build up on the piston heads, and a brass brush, carb cleaner, penetrant spray (just to keep things lubed up) to clean it up. My hands are starting to get a little sore, but at least one of the hardest parts is now over (I hope).
I inspected the cylinders and cant really tell if there was a bad problem. Everything felt smooth, but who knows what that muck and carbon build up did over time. I saw some blemishes on one of the cylinder walls, but it felt super smooth. Who knows, only a compression test will give me a good idea if it will need to be bored/new rings?
I also lapped the valves and set intake and exhaust valve lash.
Next will be to figure out what oil filter I need, fill it with oil, set up the electric start system and turn it over and test compression. Hopefully I will not cry after that.
tazmannusa
Yettem, California
I think if it was me I would pull the pistons out and check for stuck carboned up rings and scoring of the piston sides , then determine if you want to hone the bore and new rings
KartFab
looks clean. Are u gonna mill the heads at all to get a little more cr out of it?
Nope.
I want to avoid pulling out the pistons. Isn't a compression check good enough? So if i were to replace just rings, you go with stock rings, nothing oversize right? (the engine has never been opened prior to me getting into it).
I would do it as a matter of course....depending on ring cost.:thumbsup:
but that means i gotta buy a ring compressor too.
I agree.. rings cannot be too expensive, and by all the elbow grease you had to spend.. and while it's apart anyways...
why take the risk?
I'd at least check the rings now rather than regret it later ;)
[EDIT]
I installed pistons (compressing rings) with an oil filter tool (those belt thingies.. ) I'm sure that's not the best thing to do; but it worked okay'ish didn't leave a mark on the cylinder and went in nicely..
sooo I felt confident.
I'd say stock size if you do not need or do not intend to hone...
else... else ;)
Nope.
Can't say whether original size will work or not without inspecting and measuring the bore....but they usually do.
You don't have to buy a piston ring compressor or hone....just make the trip to White Settlement and spend an hour or two while we get 'er done....
Oh course, you'll owe me one of those long , uncomfortable hugs afterwards! :lolgoku:
KartFab
ok so i know for a fact that
1) it had a working air filter
2) no idea where goo came from, im guessing nat gas inlet?
3) already had 90/120 psi, psi drop between cylinders was hopefully the valve(s) not seating properly
4) it had oil it it, no milky, slightly dark, but nothing gross
5) when i popped the head, it smelled like death (ive smelled that before at a waste water treatment area of a machine shop) No water, just putrid unrefined characteristic hydrocarbon smelling
6) not a lot of significant scoring, walls 'look' ok?, wont catch fingernails on it, im sure it would be best to replace rings, and ill get new gaskets and what-not ordered after I get the engine back in one piece and running. I'll just get new rings at the same time.
Also can anyone tell me what this thing is? On the head I noticed there may have been a casting error, or a thin piece of casting that had blown through. Ideas? Theres a hole in the block that matches with this hole (that is supposed to be there). Its next to one of the four holes for the cylinder head bolts. See pics
I'd assume it's an oil passageway...
And wow.. is that indeed the piston marking mirrored in the cylinder wall that crisp?!
Yes, well.. I agree.. that cylinder isn't bad at all (it's polished alright.. but it looks prefectly fine)
the first image doesn't load for me (can't tell.. likely my ram being clogged up again)
tazmannusa
Yettem, California
Nope.
Not necessarily if the rings are gummed up with that sticky goo it could show a higher compression reading then after you run it a while and it clean that stuff out it might drop off some, burn oil and smoke.
On a compression test and you have a low reading cylinder a way to check if it is the rings or valves is squirt a little oil in the cylinder and test again if the reading goes up a little it's in the cylinder, if the reading stays about the same, it would be in the valves
On the ring size it would depend on the bore size after honed
Ok....just a little reality check based on years of shadetree mechanics coupled with HP performance engines as well....
Small engines are much more forgiving....(as are daily driver automotive engines) than HP high revving race engines....
Sooooo....that being said....everyone has heard of the "standard" .030" overbore....why is it done and what happens if you don't....
Well....sorry to say, but...it's a combination of ignorance by amateur engine rebuilders, coupled with a bit of greed by machine shops...(also coupled with "I don't give a crap" machine shop attitudes + the same ignorance and "follow the leader " mentality that brings them the business in the first place....
So now lets move to the advantages of a rebore, the disadvantages of not, and the same for a simple hone/ring replacement.
First off....most times....people just think boring .030 over is just standard procedure and necessary for a rebuild to last.....not so....
I have "rebuilt" many automotive engines that ran for over 10 years...(and never quit....the vehicles just went away where I couldn't follow them anymore) ....with a simple hone and ring replacement.....
More often than not...the cylinders can be rehoned and still be in specs. If not....then boring .010 or .020 over leaves enough cylinder for at least a couple of more rebuilds, while a .030 over often skippes a couple. The overbore allows tighter clearances...(to new factory tolerances....or BETTER!)
Sooooo.....what if those tolerances are a little looser? As long as in spec....UMMMMM....really nothing....(except they may wear out of them a little sooner) .... What if they are a little out? Depends on how and where: Taper will wear rings out a bit quicker....overall oversized cylinders...will allow some blow-by...(larger ring end gaps)....lowered compression (for the same reason) ...and possibly excessive piston rock...(due to piston bore to skirt clearances, which can also cause ring wear and compression loss).....REALITY: Unless clearances are really excessive, non- factors in a small 4-stroke engine....As a matter of fact....you may even get a little gain from less drag on the piston rings.....
The obvious advantages: cost, (no machine shop necessary) and longevity, (more cylinder to be bored later)...
Last clone I did I used my fingers and a popsicle stick. AGK shared the trick of the popsicle stick, just to help. Anyway no need to buy a ring compressor.
Another trick I got from AGK while you have the head off you can "index the spark plug"
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I just bought a ring compressor at the flea market for three dollars awesome score.
Before I had a ring compressor the trick I did was, I tied fat zip ties around each ring is tight as I could then tapped the piston back in the bore and they would slide off as I each one entered. It took a little finagling, but it worked for me a few times.
Looks good so far.
Looks good so far.
Yeah....or use a hose clamp or two....or....just go to AutoZone or O'Reilly and "rent" one for free....I wouldn't know, though,since I've owned one for over 20 years.
The amount of overbore depends on cylinder wall taper and out of round. Shiny cylinder walls are a bad sign. Why is that Denny? Well that means enough wear happened to wear all previous crosshatch patterns away. But why is this a bad thing smooth is slippery right? Well yes and no, smooth is slippery but not as slippery as a oil coated surface. You see with the crosshatch pattern in there the cylinder walls will retain some oil to keep the pistons and rings riding on a layer of oil instead of the cylinder it's self. When they slide on each other instead of the oil they wear out quickly. When you just hone a worn cylinder it will still be out of round and then you go and put in a new set of perfectly round new rings. Well those new rings just don't stand a chance of sealing to that out of round bore. Please have a machine shop measure the bore for proper taper and out of round before just throwing in a new set of rings. Other wise you could end up with a smoker with excessive blow by.
