Honda GX620 Build
KartFab
Dallas, TX
lol! nice pic there. just to catch you all up on what has been happening.
1) The shininess is from the light shining in and the copious amounts of oil i was using while cleaning the piston head.
2) There is some sort of cross-hatchiness going on in both bores, more hatchy, less crossy?
3) One of the heads had a cross threaded spark plug hole. I ran a spark plug through it coming from the other side, then had to really crank one in there the right way.
As I said before, it ran on natural gas (even though its not the natural gas engine) and some goo was introduced in the engine. The goo seems miscible with the oil and penetrating spray, dissolves with carb spray, and re-solidifies if its not wiped off after the carb spray is put on it, if it goes with the oil it dissolves and kind of becomes part of the oil.
Working on the carb now. The intake manifold was lined with the goo, same for the carb venturi. Hopefully I got all the goo out as its pretty stubborn. The bowl was virtually spotless (doesn't look like it had ever seen gasoline).
Thanks Denny for the advice about having the bore measured. I just want to see if it runs first. I'm re-using all old gaskets, and just am hoping to get it running first.
Kokamo
Azzkicker extraordinaire
Liberty Hill, Tx
I think the deposits on the piston you have already cleaned is nothing but residual oil build up in a low disturbance area. Since the NG is a "dry" fuel, the only kind of liquid in the chamber is oil from the cylinder wall that the oil rings couldn't wipe away and a little bit from the PCV system. The oil just built up because there wasn't any wet fuel to wash it away. As for the intake valve with build up, again, the dry fuel causes build up. The wet fuel acts as a solvent to keep things clean. The oil comes from the crankcase vent and builds up on things that are hot. I wouldn't be surprised that the exhaust valve was pretty gummy with goo as well.
On another note, some light crosshatches are good. No lip at the top of the cylinder is good. Slap that sucker back together and give it a go! One of my favorite quotes... "Poor folks got poor ways"....lol, that's the way I do it most of the time.
~Joe
Atlanta, GA
I know when I burn NG in my home it creates moisture (water) as a by-product of combustion. I don't know if burning CNG has the same result. But steam and oil might create a gunk like what you are describing. Maybe?
I agree the smart thing to do in this case is just get it running first to see what it needs and then go from there. If that was a oilfield engine it is possible that some of the "gunk" you are seeing is crude oil vapor that has accumulated. Good luck.
KartFab
Dallas, TX
Thanks joe, I didn't think about the crankshaft return. Exhaust valves were a little gummed up, but not as bad.
Ezcome, most combustion takes a carbon source with oxygen, then releases energy as heat with multiple byproducts, water, carbon dioxide, monoxide, NOx, etc etc. I believe burning CNG and NG are the same, it's just that CNG is regulated from a higher pressure to a lower pressure/flow rate. I was never able to see what the engine was connected to to determine fuel source.
Denny, it could very well have been an oilfield engine. Makes sense.
The good news is that I got the carb clean, intake manifold was just as nasty. Cleaned that up and put new knock off magnetos on it (old ones were a little chewed up). A little starter fluid and crank of the key and this thing really took off. It sounded amazing and powerful as I started it with no exhaust.
Back to the grind and will update when I get a chance to work on it again.
I posted a short video on Instagram of it running. I'll have to post a better video later. https://www.instagram.com/kartfab/
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
This is how I did it. Held the rings in with my fingers and pushed the piston down with my forehead. LOL :D
That is awsome! Looks like you are praying to the engine Gods or...:mad2: But a great tip if it works. Although you could have just asked whoever was taking the Picture to push the piston Down:idea2:
Kokamo
Liberty Hill, Tx
Kartfab, looking good man! One bit of advice tho....take that starter fluid and throw it in the trash. That is some bad stuff on any engine that has an aluminum connecting rod. The HX670 I have now had one of the rods shattered (literally) from starting fluid. It's just too potent. I use carb cleaner (not brake cleaner) or a little gas in a squirt bottle when the need arises for a little priming.
Looks good man! Keep up the good work!
KartFab
Dallas, TX
Electrical
Does anyone know any procedures to test the charge coils and regulator/rectifier?
I have two wires coming from the coil area, both are the same color.
I have the regulator rectifier as well. I believe it has 6 wires in the harness that plugs into it.
How do I test the coils?
How do I test the regulator / rectifier?
Can't wait to see what this is going on! :cheers2: now you need to put the muffler on it and run it on gasoline for a while.
KartFab
Dallas, TX
Honda GX 620 electrical
Parts: Well, I had to order about $50 worth of parts (new fuel pump, air filter, air filter gasket, fuel solenoid o ring, fuel filter.
Muffler:
I have a spare seized gx620, and two types of mufflers to work with. One is nicer, but fits the other style of gx620 and is oriented to blow toward the driver if I installed the engine correctly. The other is older, and broke in half with a big dent in the pipe too. Either way I will have to do a little welding to make either work properly.
Carb Question:
I also have been investigating the carb, and cannot for the life of me find out what a particular connection/opening is for. The other connections I have are for the fuel drain, fuel inlet, some connection that is at the top of the engine (im guessing it powers the fuel pump). If you notice at the top of the carb, there is a spot for a hose. My duplicate engine had a spare tube with a screw in it attached to this, and I cannot find a diagram showing what this is for. When cleaning the carb, this hole went straight to the body above the bowl. Any ideas? Also, there appears to be (labeled #1) an idle mixture screw? Dunno. There's also another screw that should adjust air in at idle -idle speed? ( labeled #2). I dont care much about those, just am wondering what that 'extra' hole at the top is for, and what I need to do with it.
Remote Choke and Throttle:
I have attached some images for the diagram to attach remote choke/throttle, and will have to get a few more bits and pieces to get it all hooked up correctly. It looks like I am actually missing a piece (not present on the spare seized engine either) that the throttle cable stop would attach to, and that the governor spring would attach to), :-( Its labelled "control lever" on the diagram. Also missing the cable holders and throttle/choke cable stops. I plan on doing a solid cable choke, and a braided cable throttle.
Wiring Dilemma:
I am finally getting a grasp on the charging system and it looks like this model may have a spot for a <2watt charging light. Anyway. I am still wondering how to test the regulator/rectifier to see if it works. I have three of them so hopefully one will work! (also charge coils? how to test?)
KartFab
Dallas, TX
Parts
Have been looking through the shop manual, parts manual, and ereplacement parts (which just copied and pasted the actual parts manual diagram) for references. Hopefully will be able to dig out what I need from this mess.
online shop and service information (gives torque values, proper gap etc) a GREAT spot, found at bottom of page.
http://engines.honda.com/parts-and-support/service-support
Parts manual found through the above link
http://cssportal.css-club.net/honda/PowerProducts/contents/1060892en_13ZJ10E7.pdf
More part numbers found at e-replacement parts
http://www.ereplacementparts.com/ho...l-engine-parts-c-37657_37658_37938_39430.html
KartFab
Dallas, TX
Honda GX620 remote throttle linkages
Well, I found the remote throttle linkage control assembly. It turns out that the later model GX620K1 uses the 'same block' as the GX670, and I had to look up the part numbers there. It was only $50+ shipping new (gags), so $15 didn't seem so bad when i found one on e-bay (whew!) Well it was a different number, but I think it should work. (the listed number is for the gx610, and the gx670 but i don't even care anymore- it looks like it should work).
http://www.ebay.com/itm/Honda-Contr...484849?hash=item2a54cf18b1:g:p2YAAOSw5VFWKO4h
I already have the wire stops, so I might just need a spring for the choke return, but maybe not because I plan on doing a solid wire for choke... ehhhh..... what the crap its only $5
http://www.ebay.com/itm/370801401874
(worst case scenario, i just tossed $20 down the drain)
Still no luck on what the hole in the top of the carb is for.
Well, I'll try and figure out some more stuff while I wait again.
Man, this sucks, but I am feeling a lot better about it now.
2SlickNick
American Minibikes @ FB
Mesa, AZ.
This beast is coming right along... Are you leaving the governor in?
I hope you do put it on the crossfire and not a little ragedy type kart like those cars and cameras guys...
They even added the 40 series TC.
You always seem pretty meticulous so I know this will turn out good.
KartFab
Dallas, TX
Yes, governor is staying in for sure. I like to keep things stock for the most part.
I will eventually put it in the crossfire, but I have to admit that I will probably put it on something else first. Sadly, I cannot find an affordable gearbox for reverse that can handle the torque coming from this engine. For now, the crossfire will just be forward drive.
That line with the screw in it is the float bowl vent. Put a length of hose on it and let it hang down to the bottom of the block. The reason for that is if the float hangs up the fuel will safely flow out of the way of hot engine parts or the electrical system. Sorry the rest I can't really help with. Maybe to check the charging system you could hook up a battery and with the engine running and with a multi-meter see if battery voltage goes up, if it does than I'd say it's working.
KartFab
Dallas, TX
Honda GX620 Muffler Reversal
As you can see from the pictures (chronological order at that), the muffler that I had would blow exhaust right at the driver if it were installed on a buggy, so I made a few minor adjustments :idea2:.
I cut the tubing in three different areas, one for each exhaust port, and once for the area where the exhaust combines. I seriously considered making a stainless steel exhaust, but this will have to do.
The left cylinder tubing was a little short as the ports on the muffler were in different positions, so I permanently borrowed two sections of tubing from the seized engine's exhaust right where it had that nasty dent.
I tack (MIG) welded everything in place, then took it all apart and TIG welded it. It feels like it has been forever since I last TIG welded, and I am satisfied with the results (aesthetics are another thing).
I also had to cut a slit in the old outlet (now inlet) for the muffler to allow the exhaust pipe to be clamped down upon.
So far so good, just waiting on parts.
