help im stumpd
nixta
New zealand
Ok I'm stumpd I've changed the fuel I've cleaned th carburetor changed the carb to the original checked the cam is dot to dot with the crank lapped the valves removed the 18lb valve springs and installed the original one's set the valve lash to the standard and tryed it set it to the cam card still the same problem motor dies when choke is switched off ........... could it be the rings are :censored: or the timeing is not rite ...
Actually what is the standard timeing for a lifan honda clone
And the compression ratio
BirdFanatic
Jonesboro Arkansas
remember i had the same problem as you try the gasket in between the carb and do you have an air filter on your carb
fowler
Bullsbrook West Aus
Yea
A/f ratio is out
Did u fit a high flow air filter
Or change your jet
When u changed the carb did u fit a new gasket to the carb and the spacer
2SlickNick
American Minibikes @ FB
Mesa, AZ.
It does sound like an air leak. While engine is running with choke on, spray some carb cleaner around gasket sites. If the engine changes rpm hat is where your leak is.
BirdFanatic
Jonesboro Arkansas
if your not using a air filter thats your problem lol i took my filter off and left it off and there was a gasket in between the engine and the carb on top of the spacer lol it was causing it not to run
nixta
New zealand
Can someone send photos or step by step gasket fitting pics so I can check my fitment is correct cheers
fowler
Bullsbrook West Aus
step by step
we assume u have removed the carb to clean it
if u havent removed the carb to clean it then u havent cleaned it
repaet the proccess to remove the carb
between the carb and the engine theres a peice of hard thick plastic
keep this bit
then between the carb and the spacer and the spacer and the engine theres two peices the same shape as the spacer
theyre thin and floppy
oftern of an odd colour like green
theyre made of paper or rupper
these are one use items
once u unbolt the carb theyre ruined and must be replaced
u need to find the carb seals and get new ones
to isolate the problem get a bit of flammable mixture like carb cleaner spray and spray it around the carb joint
the engine will suck in the carb cleaner when it sucks in the air and make it rev up slightly
be careful though
u are spraying flamable mixture on your engine
dont go overboard
and do it on a cold engine
maybe have a fire extinquisher near by
or someone with a hose
nixta
New zealand
Done this spray carb cleaner thing no rev up motor still dies changed gaskets motor still dies made sure gaskets are in rite place motor still dies. I'm almost ready to chuck it in the f-it bucket it's driving me insane dam ching motors lol
BirdFanatic
Jonesboro Arkansas
really????????????????
its true lol i pulled the air filter off carb idled but did not rev up it would bog out my father said put it on the air filter creates a pressure that helps suck gas out of the carb and into the engine (he said he read it off of a moped forum ) i can prove it to you by showing you a video of me doing it
nixta
New zealand
still stumpd
Ok taken so much advice and nothing is working even got a advanced timeing key my motor still only runs on choke dies when choke is switched off any ideas guys I'm really getting extremely:censored::censored: off any help would be good cheers guys
nixta
New zealand
My motor not running right it dies when the choke is switched off ...i.e... only idles on choke dies instantly when choke is switched off
