HELP I got a go kart with 169cc engine
RandomK
I got a go kart with a 169cc suburu engine and I would like to change it for a predator 212cc. Is it the same build plate size so I can just bolt it in and not have to change anything?
keep the robin subaru on a shelf as a backup engine.. it'll outlive several predators ;)
(and with 6.5horses it's not even less powerfull than a stock predator)
there's just no aftermarket modding parts for one really...
but left stock, it's about as good as an engine can be;
So yeah, if you want it to be reliable, keep the subaru as a backup just in case :D
RandomK
Okay thanks... but do you know if the mounting holes on the predator are the same as the suburu
RandomK
What should I get to make this go really fast. 18inch wheels and a 196cc suburu and a tourque converter go kart? What gear ratio for top speed?
JTSpeedDemon
Texas
What gearing does it have? What top speed do you want?
Moreover: :useless:
We need pics, and a detailed request to be able to help you. :toetap05:
RandomK
How much do you think this go kart is worth
---------- Post added at 03:37 PM ---------- Previous post was at 03:36 PM ----------
https://photos.app.goo.gl/YBJPMpBEEG1y3YKdA
---------- Post added at 03:37 PM ---------- Previous post was at 03:37 PM ----------
https://photos.app.goo.gl/hkPrKoRhpjNpEiweA
RandomK
I'd pay 200$- for it... but it needs a gas tank. Is that good?
What speed do you think I would get outta this
Smerft85
Southern Colorado
I'd build it and thrash it. You'd likely put more $ into it to fix it enough to get half your money back. I know my dingo of similar build with a 212 clone does over 40mph with only a governor delete, I don't remember it's ratio off hand but it's running 18" rears too.
Dingocat
Broke
NE Ohio
Lights require a battery that you will pull off and charge or an engine with a charging system. I wouldn't pay more than 180 for that go kart. That's if the subaru will run off starter fluid.
RandomK
Ya the engine starts with starting fluid and all tires are good and all tires are good
RandomK
Okay thanks
---------- Post added at 06:38 PM ---------- Previous post was at 06:04 PM ----------
He has it posted for 300. Lowest he can go is 200. And it has a tourque converter. The sticker says it's a red fox LXT and its extended
Smerft85
Southern Colorado
Okay thanks
Extended as in a stretched frame? Ultimately it's up to you, I think $200 in that condition is quite a stretch, entire frame could be crooked like the stretched dingo I picked up, and have since parted ways with. Without knowing the owners fabrication skills $150 is probably a high offer.
