so if there is a key in both the tc and drive sprocket we havent solved the problem
dont weld the sprocket if there is a key in there no reason.
at the begining i thought i may have to do with your belt.
when you spining the tire does the tire spin the sproket. and does it spin the jackshaft. if it does then there is somthing wrong with your belt or just your tc
