HELP! Go kart wont go forward
fowler
Bullsbrook West Aus
see the grub screw in this pic
u will have one in a similar place
but it could be anywhere along the driver
take pics of the driver and we willl tell u where to put one
as r97 said u may have to make one.
but it is easy and if u are not confident then a machine shop can do it in 15minutes for u
bullrider700
well when you have a retard trying to fix a kart and so many knowledgeable people on here its easy! hahahaha
r97
Measure twice cut once
Massachusetts, USA
the nut on the end of the jack shaft should be up against the TC so they key cannot come out. the key should also be as long as it can be but still allow for the nut to be tightened.
if everything is correct, you should not need a hammer, if you do need a hammer, don't use one, find what is causing the need for a hammer, and fix it.
fowler
Bullsbrook West Aus
i always use a hammer
but not a giant sledge hammer and dead blow hammer
i find even on totally new products the key is always a bit tight
stops it coming out that way
r97
Massachusetts, USA
huh, thats weird, i have never had to use a hammer, the key is usually tight, but not THAT tight.
EDIT: i suppose a few taps with a small hammer would be normal, i usally just force it in with my finger.
bullrider700
Ok I just got the nut off and there is no hole for a bolt, I dont have a way to get my phone hooked up to the computer right now. I can text a pic to one of yall if you pm me your number.
r97
Massachusetts, USA
email the picture to yourself from your phone and get it on the computer.
home depot might, mine doesn't, but my home depot doesn't have anything...
bullrider700
here ya go
fowler
Bullsbrook West Aus
u will have to get a locking collar for the inside and a big wassher for the outside
a locking collar is the pic above it will shtop the key sliding inwards and a big washer to cover the hole on the out side will stop it slideing out
there isnt a hole on the inside of the driven
between the two pully faces
bullrider700
Cool Ill toy with it tomorrow and give yall an update. I have to get off of here for a sec Ill be back on here in about 20. Thanks so much for y'all guys help!!!!! Glad it is a cheap fix, thought something was wrong with my tc haha
bullrider700
not sure its the jackshaft that the sprocket and tourque converter is on, the key notch stretches out from the sprocket
