Headers
Atlanta, GA
My house was built in 1949, likely by the original owner. Nothing is plumb, square or standard. I build my own doors these days for these reasons. Those screws might be overkill, but if this task didn't GAB I'd be disappointed.
I think I googled which screws to use for prehung interior door then added 1/2” for extra layer of drywall. I think that’s how I landed on those.
Atlanta, GA
The screws are for the trim? I'd use those screws to hold down exterior decking. At the end of the day, screws are screws.
Not the trim. To hold the door jam. Door jam is probably 3/4” thick? Then 1/2” of drywall? Then behind the drywall are the studs I’d need to screw into.
I don’t have a nail gun (or air compressor anymore).
For the trim I think I was looking for 2” 16 gauge? Then use a punch thingy / nail-setter and hammer to install the trim. Maybe pre drill the trim?
You know this is going to go well when my first choice was to use a utility knife to remove the trim instead of looking for the proper attachment for the oscillating multi tool.
Now what to stuff inside the gap above the door jam? For insulation purposes. All those Amazon bubble mailers?IMG_6949.jpegimage.jpg
Hey Bob,
Looks good :thumbsup:
but,
On most door installs I've seen, the hinge side was attached, to the wall, flush/good-n-solid
...& then, the latch side was shimmed ;)
What if the hinge side isn’t plum?
The shims aren’t there just to act as backing for the screws, they are there to keep the jam straight up and down, aligned with the forces of gravity.
On many of the videos I watched, shims on the side of the hinges (right above, below, or behind the hinges) are common.
