Hair pulling engine trouble!
NapO
Canada
I have just finnished installling a numerous amount of modifications on gx160. i can get it started but the things is running really, really rough. i can barely get to idle. first what should my fuel mix screw be set at? i have it three turns out . also i have a 95 jet in the carb now, it a gx200 carb that is bored out to about to 16mm. i order all new gasket and everything. the valve lash is set to the cam specification which is 002 intake and 003 exhaust. also when rev up with out joke it start to knock pretty hard. the head is 14cc with gx200 gasket for about 10 to 1 compression. can someone help me to get this thing running right??? thanxs any help would be amazing
BAMBY
MINI BIKER
Naperville, IL
might be a dumb idea... but are you running higher octane gas for your high compression ratio?
also, the standard for briggs carbs was always 1.5 turns... idk if they are similar or not, maybe you could give that a try... also, i dont know how this is affected by your larger jet and bored carb...
i would wait for jr drag tyler or any of the other guys that have experience with the modded clones to be sure though...
in other words... bump. hahahaaaaa
sorry i couldnt be more helpful, im more of a flathead guy...
BAMBY
mike75925
thinker and tinkerer
Alto, tx
without listing the mods, i doubt anyone could say what will work. if it is knocking pretty hard, you may be over advanced on timing. since you can barely get off idle, i would say swap in a bigger main jet to see if that helps. as for idle tuning, 1 1/2 turns is for stock, you may just have to play with the screw. on the miks, they say if you are more than two turns out or 1 turn in to go with the next jet size. if in, go smaller on idle, if out go bigger
NapO
Canada
before i was running 93 octane now im running the regular 87 octane.. i'll have to try that. these are all the mods that if have done:HS Engine Bolt Kit (head and side cover) $12.00
200-252-0211 Camshaft, New, NRC-252 $109.00
Part->7351448 Piston, Lightweight, Flattop $25.00
Part- T2 160/200 Ring Set Honda OEM, Top, Standard $26.00
Part-CMPUSH Pushrods, Chrome Moly, 5.26 $24.00
Part-ARCROD Rod Connecting, Billet (Bearing included) $59.00
Part- Springs, 26 lb $6.00
Lash caps $10.00
gx200 carb bored out with 95 jet
gx140 emulsion tube
1.2 ratio rockers
remove fins off the fan
diamond fire spark plug
8 degrees advance timing
ss valves
billet retainer
header
Russ2251
AZUSA:Powered by LAWN-BOY
If he removed every other fin...should not be a problem. Hopefully, they were machined off.
8° advance seems kind of heavy, even with all other mods. I would drop it back and see if improvement can be observed.
NapO
Canada
no it's every other fin sorry that i didn't state that..it working fine with the 8 degreees of timing before though
Kenny_McCormic
Kartless....
Michigan Troll
Ditch the bull**** plug and put a NGK in it. 10:1 is pretty high for a air cooled 4 stroke on pump gas, especially with 8* advance. Bored carb and big cam could have something to do with poor idle. Very dangerous idea to run the cast flywheel with 26lb springs. NR says the 0211 is designed for 9.5:1 or lower compression.
NapO
Canada
the plug was black after 1 minute of running. i put the 90 jet in and workin a little better. im thinking of putting the gx160 head gasket in to lower the compression a bit. i didn't bore out the carb that much maybe 1mm. i asked the guy from nr racing he said my set up should be ok. ill be kinda pissed if i have to put in the dished piston in. i think compression maybe to high. im thinking of taking it to small engine to get it properly tuned. lol kinda fustrating me.
mike75925
Alto, tx
be ready to open your wallet. i don't know how much they charge there, but i think it is 45/hour here. even if it takes 2 seconds. um, this guy i know, he's supposed to be a great mechanic, said he had to put like 50* advance on his chevy. i was like wow, it runs like that? anyway, he is pushing around 600 off of pump gas. i forget what all he did to that thing.
NapO
Canada
all the parts should work. i asked a bunch of different engine builders. i juts got to find how to tune this things. plus my recoil spring just snapped. just keeps getting worse and worse lol.
r_chez_08
Should be in the shop...
Cornwall, UK
i feel like that sometimes with my kart, but dont let it put you off. when it works it will be satisfying.
jr dragster T
Cold place
Plug comes out black? Runs rough? Choppy? Blows black smoke like a freight train? Sounds just too rich to me/too much timing.
