Hair pulling engine trouble!
NapO
Canada
i put the 90 jet seems fine. i think the compression is killing me. i checked the chart and it said i have almost 11.5 to 1 compression. if i add gx1600 head gasket it should bring it to 9.8 closer to the 9.5 that is stated. good idea?
1992suburban
I wanna go FAST!!
Sanford, NC
you runnin 93 octane??
is it a GX160???
if so... drop back to a 4 degree key the 160 flywheel has 4 degrees MOREtiming built in then the GX200 so YEA it may be hurting you on pump gas need methenol
NapO
Canada
even before i installed thses new parts i had trouble getting the engine to idle without the choke so this problem is not new.
1992suburban
I wanna go FAST!!
Sanford, NC
try 93 octane maybe with a lil octane boost 1st
also.. did you drill the low speed jet out?? it helps the idle quality and ease of starting
mike75925
thinker and tinkerer
Alto, tx
do you know which 160 head you have? take a syringe, flavor injector or even a liquid measuring cup if it has ml on it. fill the heads cavity with water, and pour off into the meeasuring cup.
NapO
Canada
im pretty sure the compression needs to be changed
the reason y i did some of the mods was to get rid of the idle problem. i think it must have been the timing all along. i even bought new gasket and a carburator.
NapO
Canada
i tried the lower compression with the ca. it started over reved like crazy at mid choke then died. now it won't start anyone have any other ideas?
i really wanna sell the piece of crap. is it un common to perform these mods and not have engine work at all. i checked everyting and it shhould work fine.
Kenny_McCormic
Kartless....
Michigan Troll
A good lesson to all.
Bring engine up to stock first BEFORE making mods.
Otherwise you do not know what you have.
In the words of an old stock car driver my Dad knows, "I was blowing the doors off of Corvettes with tunnel rams and stuff in a 55 chevy because they just couldn't get it all to come together."
NapO
Canada
toronto, canada. i think it's major carb issue becuase it seems that it's not getting gas and when it does it's too much and over revs with choke on. i think this was linked to idle problem before but should a brand new carb get rid of that? it's a no name carb.
NapO
Canada
i believe u and i'm coming to think thats is right. it's very diffuclut to judge since u can't see i know. umm is was gunnna use mikuni before that could have been worse. should i buy gx 160 carb? it says to use larger carb with this cam though
