H.F 11hp gov. removal
Mzguns
H.F 11hp key start needs moved
Can anyone tell me how hard it would be to move the electric start key panel to the drivers control panel.
r97
Measure twice cut once
Massachusetts, USA
take bolts out, cut wires, solder longer pieces of wire in, shrink wrap, bolt in desired location.
redsox985
PA
25 percent!?!?!?! I'd rate it at least 1/4 difficulty. AT THE LEAST!!!!!
r97
Massachusetts, USA
like 1hr (max) of work, not a big deal, prob about as much work as it is to install a new light fixture.
Mzguns
thanks guys as you can see i am new to this. sorry for the double thread topic i dont know how to change it .
r97
Massachusetts, USA
i have tried, lol. you can change the title by clicking the "edit" button on your FIRST post of this thread, then "go advanced", then just simply place your cursor in the "title" box and type in what you want.
jr dragster T
Cold place
Its 3 wires. 1 Positive to the switch from the positive in on the hot side of the starter solenoid. 2 is Positive trigger to the solenoid when key is turned to start. 3rd wire is from the ignition coil. Not a hard job at all.
r97
Massachusetts, USA
i recall it being 5 wires, maybe i'm too tired. lol. you could prob set it up with 3 though.
i think this is pretty standard, wiring (please note you only need to extend the 4 wires on the key switch(big circle thing), then ground to the frame),
