GX390 Boat Build
65ShelbyClone
SoCal
What grade of titanium are you using?
Using big ol' taps and dies on Ti is really going about it the hard way and I get it, it's out of necessity. It would be a lot more cooperative with single-point threading in a sturdy lathe. It has some similarities to stainless steel.
Mammoth
Durham, CA
Yeah, single point on a lathe is a much better way to go for this type of job. Carbide vs Titanium.
I don't have access to a lathe right now, so I'm just getting by at this moment in time.
Its 6AL-4V Titanium
Mammoth
Durham, CA
Had to match the propeller shaft tunnel to the front of the propeller.
Got a tube and bored the inside to accept a seal. This will actually be a second seal to keep water out of the hull.
Had to go right here.
Then welded the tube to the propeller shaft tunnel. I battled everything imaginable to get it welded.
Still working on smoothing out the seams, but it should have a lot less drag like this.
SUH-LOOT! I cant imagine starting on that first bead, knowing how much more was left. Jeeeez!
Nice work man.
Mammoth
Durham, CA
The tunnel has to curve back down to the water line for it to work properly. I don't pretend to know how it works, and opinions seem to vary wildly on the internet. I took my best shot at building it.
Next is to make a rudder.
Mammoth
Durham, CA
Installed 3/8" thick UHMW to the bottom. This will add some weight and cause drag, but the bottom will be able to handle harder impacts and it will slide way better over rocks.
Mammoth
Durham, CA
What is UHMW?
Ultra high molecular weight polyethylene. It's a dense material that can handle impacts without taking damage, and has a very low coefficient of drag.
Aluminum on rocks creates a lot of drag. With UHMW I can drive right over a gravel bar like its sliding on ice.
