GX390 Boat Build
65ShelbyClone
SoCal
What grade of titanium are you using?
Using big ol' taps and dies on Ti is really going about it the hard way and I get it, it's out of necessity. It would be a lot more cooperative with single-point threading in a sturdy lathe. It has some similarities to stainless steel.
Mammoth
Durham, CA
Yeah, single point on a lathe is a much better way to go for this type of job. Carbide vs Titanium.
I don't have access to a lathe right now, so I'm just getting by at this moment in time.
Its 6AL-4V Titanium
Mammoth
Durham, CA
Had to match the propeller shaft tunnel to the front of the propeller.
Got a tube and bored the inside to accept a seal. This will actually be a second seal to keep water out of the hull.
Had to go right here.
Then welded the tube to the propeller shaft tunnel. I battled everything imaginable to get it welded.
Still working on smoothing out the seams, but it should have a lot less drag like this.
SUH-LOOT! I cant imagine starting on that first bead, knowing how much more was left. Jeeeez!
Nice work man.
