What would be the best gear ratio to run with the torque converter if I plan to run the nine or 11 horse motor? I have 11 inch slicks right now, but thinking about buying the 13 inch slicks from gokartparts.com.
Also, I am planning to remove the governor, but I heard you need to upgrade the engine or risk it detonating. (Which I just found out is what happened to that Honda) So should I buy the 6.5 HF motor and upgrade it, or just go with the nine or 11 horse from the surplus center, and probably leave it governed. (Or I was thinking about putting a throttle stop on the carb lever to prevent it from running max RPMs?)
