Ok, last big push to try and hopefully get a Test ride in on Sunday or Monday. To do list:
-Tonight weld on the bracket for the second hydraulic brake, the hand brake line. Install Brake lines to Brake caliper.
-Weld on 2 brackets for the tow bar that will bolt up to the front bumper. This will be for a tow bar to tow small distances (with chain removed so its essentially in idle).
-Saturday, check all bolt/nuts, and tighten things down. Check all keyways for keys. Drain break-in oil and put new synth oil+filter in
A few notes from pushing it around: the second caliper was a good call. The single MCP caliper will stop it, but its a little slow. It reminds me of my old 650-ish pound Goldwing that I rode for years with 1 caliper.
It doesn't turn super easily on pavement due to the wide solid axle. It will turn, but you can tell its gripping. Exaclty the same feeling when having 4x4 lockers engaged on a truck. But it should be fine on soft ground.
Wish me luck....
