TNThomas
OK, officially finished the last of the welds today! The swingarm is finished, with the "redneck reverse" installed. Bench tested it/the starter, and it works great. Took a while to eyeball proper gear alignment and make my marks/cuts/drill holes/welds, but the reverse is on. I'll put a push button switch on it and mount it left of the steering wheel. That way I could get out, push, and engage the reverse all at once by myself if ever needed. Not bad overall just a decent amount of hand fitting. Cheap flexplate ($28) from Autozone. Starter came off a Corvette, got it for $20, and the weldable hub from Nitro chain was about $11 or so. Anybody reading this who is contemplating doing it, the flex plate is about 14" in dia if I am thinking right, and you could definitely weld both the flexplate, and a sprocket from Nitro chain to a single hub. I didn't need to but it would be possible.
Gussets mounted to 2"reciever on the back, on 3 of the corners on the swingarm, one gusset for the alternator bracket, 4 gussets on the bearing mounting plated on the bottom center, and 2 zip tie welds tabs for the brake line. I was looking at the support bracket for the starter and thought it looked real close to the dimmensions of a 30 cal ammo can, so I checked and indeeded it was. I welded in a few gussets that double as holding the 30 cal can in place. Good little spot for waterproof misc storage. Man this thing took a while! I'll clean up the metal and get the swingarm painted over the next few days. Then install all the stuff, then figure my wiring out.
