governor removed with pictures.
dirtrider69
dover tennessee
yea i just took the motor apart and put everything back togeather except the governor assy. so i put the little rod into the block and the little linkage thing like pic 9 i just riveted to the engine block but i gotta take off the pastic gear and cut the little lever thing off the govenor rod......
ironman
I'm Back!
kentucky
i used the grinder and shaved it down that way work fine for me.what shape was your motor in when you took off the crank cover was it pretty clean.
Jblankster
Illinois
great watch out alot of people say you shouldnt take governor off because those motors have cheap parts in them,and at higher rpms motor will come apart. but ive talk to my local shop they told me they would be fine. let me know how your does and how fast you get it ok. this is always good info to know about first hand.i also have a h.f. motor
briggs engines can take it. the clones are the ones that cant
gocartkid
Bad Attitude
CT
That's similar to what I just did. I found a rod to go through the hole snugly, and I'm going to epoxy it in there so there are no leaks. :thumbsup:
steve lord
steve lord
Governor adjustment?
Can you ADJUST the governor? . . . . instead of taking it off?
Steve
kibble
I banned myself
Steve
Possibly, but it wouldn't be safe because then you'd have the gear inside rotating faster than it should be and like oscar said, it'd probably fly apart.
kibble
I banned myself
Yes, and there's a dark secret behind it.....
MUAAAHAHAHAHAHAHAHAHAHAHAH!!!! :devil2:
beansdaddy78
JR. Member
Carbondale IL.
i got my case off but im not sure exactly where to cut my rod, then i dont know what else to do , im sorry im so nervous that this thing wont work after i put it together that im afraid to make a move without someone holding my hand, its the only running motor i have at the time. any help would be appreciated
pic below of the rod, can you give me an idea of how much to grind please
I have answered your question in your briggs thread
