just make sure the lever is not left on it could bind in the cam.
And the crank for Hondas
great watch out alot of people say you shouldnt take governor off because those motors have cheap parts in them,and at higher rpms motor will come apart. but ive talk to my local shop they told me they would be fine. let me know how your does and how fast you get it ok. this is always good info to know about first hand.i also have a h.f. motor
yea i just took the motor apart and put everything back togeather except the governor assy. so i put the little rod into the block and the little linkage thing like pic 9 i just riveted to the engine block but i gotta take off the pastic gear and cut the little lever thing off the govenor rod......
Can you ADJUST the governor? . . . . instead of taking it off?
Steve
Steve
Steve
i got my case off but im not sure exactly where to cut my rod, then i dont know what else to do , im sorry im so nervous that this thing wont work after i put it together that im afraid to make a move without someone holding my hand, its the only running motor i have at the time. any help would be appreciated
pic below of the rod, can you give me an idea of how much to grind please
