got 2 electric scooters
gvfc2
wishing i was living
Tacoma,wa
haha ok i guess ill get it. only problem is i would need to get a new rear rim. its currently set up for a belt. unless i could install a jackshaft
gvfc2
Tacoma,wa
its a split hub and the pulley is actually part of the hub. but i will look at it alittle later. when i go out to get pics i will take it apart
its a chinese scooter btw
gvfc2
Tacoma,wa
yes the belt pulley is a part of the rim. i didnt get the size ill go do that now. ill take some pics so you can see the scooter. from what i read on it its a ripper brand i think thats what it said
got some pictures. the wheel size reads 200x50 looks to be 10 inch in diameter
beansdaddy78
JR. Member
Carbondale IL.
Im thinking its also the batteries. I will check everything tomorrow. I got a question about what type of engine to use. I know a 2 stroke would be better than a 4 stroke. But what size and brand? Thats kinda cheap
i got a tecumseh 2.7hp 2stroke that runs, let me know if you think it would fit and work with your set up, also have a clutch for it
beansdaddy78
JR. Member
Carbondale IL.
nice looking scooter would this be a good engine?
that looks like the motor i got on one of mine, people tell me that its not a 47 or a 49 but its a 43cc . they told me it was mismarketed
supposedly you can tell by the way the fins go around the head, i cant see the head percectly clear but it looks like the fins on mine and my motor is the smaller 43cc that was sold as a 49cc
gvfc2
Tacoma,wa
how much for your engine? could i get a vid of it working?
i know not the best. not talking about quality. but you can get the gist of it the yellow one im keeping electric
gvfc2
Tacoma,wa
yes its 5/8 sorry for the late reply. have you been able to find anything yet ML-TOYS?
gvfc2
Tacoma,wa
its fine. know any place else to find some? i guess my next best bet is to go to HF and get a 10inch rim and wheel
augidog
you can also explore using friction-drive parts as an easier route than mixing and matching wheels & sprockets & whatever. you can find ready-made clutches & rollers that'll bolt right on to these engines.
and just so you know:
that 47cc engine comes with a bowl carburetor and requires a gas-tank that's higher than the engine for gravity-feed. you can buy diaphragm conversion kits, but they will double/triple your final cost.
the other style, 22cc-49cc, uses a diaphragm carby, and you can place the tank anywhere. you can also get versions with an attached tank.
for reference only, not a recommendation, just a good look at your options:
http://www.partsforscooters.com/All-Parts/22cc-49cc-2-Strok-Engines
PSA: it's my small-engine opinion that what you're looking to do can be accomplished with as little as 22cc, especially if you have an eye open for legal & social tolerance. be mindful that gas motorized bicycles have become illegal in WA because of abuse, you wouldn't wanna let that happen to scooters too.
gvfc2
Tacoma,wa
no i would not want them to become illegal.
so a 22cc will be able to get me going close to 20-30mph?
