got 2 electric scooters
gvfc2
wishing i was living
Tacoma,wa
one im gonna put a gas engine on the other im gonna fix and sell.
my question is why wont it charge. i plug it in it gets power the headlight turns on the turn signals work and everything it just wont charge. i also dont have the key for it... got them both for 20$ ill get out and take some pics in alittle bit but right now im hungry
ML-TOYS
long island, new york
well you either have a bad battery or a bad controller.
also the scooter will not run with the charger plugged into it.
BTW how do you know its not charging if you have power everywhere else
also what brand and model are they
kendelrk
redneck engineer
westland michigan
Im not entierly sure but did you turn the lights off? Not sure if it has power switches for lights and such but them being on will draw battery power thats coming from the charger
gvfc2
Tacoma,wa
i know its not charging because i left it alone for a day and then unplugged it and nothing. all lights were off. the main one im concerned about is a xtreme x360 electric scooter moped
the other scooter im just going to put an engine on it because i dont like taking the bus and id have to go like 20 miles and 1 charge would be just that. and an engine would be faster
ML-TOYS
did you physically test the batteries with a meter ?
thats first,
if voltage appears then unplug the motor wire and check for voltage coming out of the controller while twisting the throttle.
if none check the throttle with a continuity or ohm meter.
also check the output on the charger itself.
gvfc2
Tacoma,wa
Im thinking its also the batteries. I will check everything tomorrow. I got a question about what type of engine to use. I know a 2 stroke would be better than a 4 stroke. But what size and brand? Thats kinda cheap
gvfc2
Tacoma,wa
the problem with the bigger engines cant use it legally on a scooter now the 2hp one i might be able to get away with. has to be under a certain hp rating. i think under 1hp but they cant tell just by looking at the 2hp
gvfc2
Tacoma,wa
yes it needs to be legal. i will be using it on the street. main streets at that. but im pretty sure i can get away with a 2hp
ML-TOYS
but like i said i dont think any thing that small can have anoghf power to ride on the road
all of the scooters and pocket bikes come with those motors on them, some even have a 43cc motor. i dont understand your logic that they will not have the power for on road use.
they are not the same as weed eater motors that are 23cc.
cumminsbayou4x4
fairhope alabama
yeah i know they come on pocket bikes and scooters but those road legal because they don't have the power to power some one 40mph and to be able to pull out on the road and not get run over
