firemanjim
Just kartin' around....
If it where me, I would lower the current tank to just below seat Height to avoid any fuel spill/slosh. Then add a pulse pump.....
well, I like my balls more than head
There should be enough torque cose on this engine instead originaly 13" wheel I put 40 tooth sprocket and on gokart axle is 28 tooth sprocket... Just trying to compesate replacing 13" wheel with 5"...
Hope you got my point...
Good, cose my english is much better if I can use arms and legs
No return line needed. You only have the fuel line with a pulse pump in the middle somewhere . That has a line for a pulse (suction) from a vacuum source on the engine, like the manifold. It only pumps what you need.....
sprockets on engine side is 40 and on gokart axle is 28 tooth, ratio is 1.428...
may be better if it wont start if that frame is made from water pipe! just sayin
