gokart Fxr 180
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
Hi ...
year ago I started my project but do not have much time so ..
I got 5'' wheels, 180 ccm scooter engine (2 stroke) from gillera runner 180 fxr ...
instead of rear wheel I put sprocket and then use conventional transmition via chain.
gear ratio is 40/27 and top speed should be 80 km/h ...
start:
brakes:
sprocketss before :
and after:
pedals:
as original exhaust could not fit, I changed pipe a little bit and probable lost some power...
radiator is from ford tranzit cabin heater :
how should everything fit:
after complete disassembly and checking welds, sanding old paint , primer paint is there:
and after black:
plan is to paint main tubes in orange and put evrything back.
This is some great work; I like what you did with the sprockets & great idea using a heater core as a radiator :thumbsup:
Welcome to the forum
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
thanks .. didn't turn out as I expected .. orange just didn't glued on black so have to fix it with brush cause I got no patience to sand it down and respray ..
firemanjim
Just kartin' around....
Houston Texas
:lolgoku::lolgoku: I know THAT feeling.....
Good job! But, the sprockets..... Man, that arrangements looks off a little, meaning you will be going super fast on top end, but take forever to get there. Unless I'm missing something...... :oops:
Slap on the wheels and post a video of it running. I bet it's quite a bit of fun to ride and I'm sure your friends are jealous..... :kewlsmiley::cheers2:
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
of course I could be wrong but hope not :D
in morning I will put some calculations here, now have to put children in the bed :p
this engine has TC inside and 13'' wheels and goes 130 km/h.
if I put 5'' wheel , it will go only 30-40 km/h so have to add some revs on axle
firemanjim
Houston Texas
Don't worry about calculations..... Just run it..... I think you are correct.... It HAD a 13" tire, now your going to a 5".... Uhh, get race slicks in a 13" height on 5 or 6" wheels.....
I like this build more n more..... Ready to see it running and what kind of pep it has......
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
ok, new calculations ... on some sites I found that top speed of this bike is 108 or 130 km/h ..
tyre used is 130/60-13''.
so diameter is 13'' + 12 cm which is 45,02 cm or 0.4502 m
circumference is Diameter * PI => 0,4502 * 3,141 = 1,413 m
top speed 108 km/h = 30 m/s
rev on axle = 30/1,413 = 21,77 (1/sec) = 1276 rpm
sprockets on engine side is 40 and on gokart axle is 28 tooth, ratio is 1.428
so gokart axle will do max 1276 rpm * 1,428 = 1822 rpm => 30 (1/sec)
gokart wheel is 5'' and whole tyre is 10" or 25.4 cm or 0,254 m in diameter
circumference is 0,254* 3,14 = 0.797 m
top speed sholud be 0,797 m * 30 (1/sec) = 24 m/s or 87 Km/h
if bike top speed is 130 km/h then kart will go 101 km/h ...
if that is case, then I sholul check welds again ...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
there is some updates,
chain is up:
radiator:
brakes with wire:
as motor starter was on left side gotta change it and put it on right side :
kart with tyres on (toe and camber are not seted up yet):
new tyres waiting to be burned:
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
well, here are some old videos , back in 2010 when I bought second hand gokart..
same engine was on, but chassis was horrible, cuted and welded so many times. ..
also, there was no exhaust, just pipe and finally i got crashed and twisted chassis beyond repair...
took two years to start build new one...
videos are poor quality, specialy this from down hill run without engine ...
downhill:
https://www.youtube.com/watch?v=rcrziuwT3XE
my test driver:
https://www.youtube.com/watch?v=3y5KCVga4fQ
https://www.youtube.com/watch?v=KQFlD5yOWhQ
zbuck
Ft. Wayne, IN
:wai: Nice job. But I am not big fan of having the gas tank above my head. If it were me, I would put it under the steering tower and add a fuel pump.
firemanjim
Houston Texas
No return line needed. You only have the fuel line with a pulse pump in the middle somewhere . That has a line for a pulse (suction) from a vacuum source on the engine, like the manifold. It only pumps what you need..... :cheers2:
