Go Kart With Snowmobile Engine Build
Desertduler
I may be wrong but is there suppose to be a bowl on the bottom of that carb since it looks like there is a float hanging there.
If so its gonna be a tough job getting it to run.
What looks like a float exposed on that carburetor is a fuel filter that mounts to the bottom of the diaphragm carburetor that is mounted to his engine.
fourtogo
With all due respect to you I can see by your old photo pitching it sideways that you know what you are talking about :thumbsup:
This is what I am driving now, there's not much in the way of new parts on it when I built it . Used frame / used engine / used steering pieces / used brakes / and used wheels . If you are thrifty and sharp about what your final out come of your Kart/Racer/have some fun unit. You can be real happy with your project. I never look at a project as, Oh this will be to scary, just hey man this is going to be a hoot! . Your right foot is were you will find your limit of fun. Too much foot is ether way to much fun, or I need a little less fun with less mash on the gas .
rushking19
Richmond Virginia
Nice kart what's the top speed of that kart
Desertduler
What a fantastic kart you have there!Thanks for sharing!
I love it!:thumbsup:
Is that a 450 Honda engine you have in that kart?
A hydraulic disc setup can be found for as little as $40 or as much as $400; what you need to do is deteremine where you need to go in that range...
As well as being under efficient, it's very easy to find a setup that's over efficient but, having said that, I suggest something from a medium to large sports bike or ATV...
rushking19
Richmond Virginia
I need to find something cheap really cheap,and what about disk brakes
No, you don't! Have you ever heard the phrase
"with great power comes great responsibility"?
By adding an engine to a little go kart frame, you create a deadly weapon; it's one thing to make a kart go fast but, in turn, it needs to steer & STOP as well as it goes! The last thing you want to cheap out on is the brakes...
Having said that, check your local scrap/junk yard...
Seriously? What part of
did you miss?
rushking19
Richmond Virginia
did you miss?
OK I'll check my local scrap yard
2SlickNick
American Minibikes @ FB
Mesa, AZ.
I look forward to seeing projects get off the ground, go through progress, and seeing finished projects.
I am thinking you might have to delete this thread and start a real project log. In ( soon to be 8) 7 pages I have seen a single bolt from a axle sprocket removed.
What does the Fox say???
:yawn:
rushking19
Richmond Virginia
:yawn:
Lol I know I was thinking about that too, I'll start the real world when I get the engine :lolgoku::iagree:
