rushking19
First off. no
Second, why would u want a centrifugal clutch, to replace a torque converter which comes from the factory on every full size sled engine?
Because the engine I bought doesn't have one
First off. no
Dude, been there, done that...
That particular clutch may be "extreme duty" but, I'm still to see a Hillard clutch that can handle 40hp... & before you start on about "the engine is only 36hp, you need a clutch that can handle more hp than the engine will make...
You should just take desert dulers's advice and get the Noram clutch! and buy his adapter.
The question is will the norm clutch handle the power
He told you in the 1st page that he uses it, on his rotax!
HERE http://www.noramclutch.com/centrifugal-clutch/trilobe.html
I feel like these guys trying helping you are ...
either that or you are![]()
Thanks Alot, there expensive though
Yes they are.....but you have an engine that is going to require an expensive clutch. There is no way of getting around that fact.
that clutch is rated for 7 hp...... I see that it holds up well, but how long do they last on that kart pictured? And what chain are you using? As in brand name? To hold up to 30 hp play time is a great testament for the little old #35...... Man reading this daily gives me a headache, but kinda entertaining.
I got it, build a wood kart for it then use rear sprockets from a bike so you have multi gears. Push type Lawnmower wheels and scrub brakes and your good to go.
I think this is the funniest post I've ever read on here......
@MLtoys, that would work if you use the gear set from a mountain bike cause those are designed for rough mountain riding...... (NO you can't use those either.....)
I used to use a "wood tic" @ a place I used to work at like 22-23 years ago. I used it to unload chemicals from ships on the docks. It was , like, dangerous stuff I guess, cause it's the only thing we could not unload with the forklifts. They wanted this stuff done by hand, 60# buckets..... With a skull and crossbones on it...... LoL
http://www.diygokarts.com/vb/picture.php?albumid=692&pictureid=4199
http://www.diygokarts.com/vb/picture.php?albumid=692&pictureid=4198
If you look at these pictures one can see what is burned up on my kart in one day and it is not the clutch!
Notice the color of the clutch drum no discoloration of the drum from slipping.
This engine is rated in its stock form as 23hp @ 6000 rpm and I have done a little tweaking to it so it has a little more than that.With a little modification I am able to use this Comet 206169 clutch that is rated oh dear should I say 8hp on this engine and another one just like it on my 303 wankel engine it can be done I have done it and I am still doing it and I will continue doing it with the wankel engines. I have many hours on this set up but I modified them myself and tested the set up and it has worked.One takes a risk in experimenting with modifications and configurations and you must have some in depth knowledge about what you are doing or else it could cost you big time.
Rushking19 just go with the stock CVT set up your kart will have a wider range of performance and this would be the safest way for you to go.
