(Go kart) Grinding noise when crank start
Cool... Thanks...
The wire from the block... Goes to the gold block... Just unplug them...
The one from the gold block, cover back up to prevent from grounding out...
Shikerwolf
Oh yeah...that engine definitely comes with a low oil sensor that needs to be disconnected.:thumbsup:
That's why it dies in turns.
Disconnect the yellow wire in pic #2 and wrap it in tape so it won't short out....done.
So... Screw off the bolt and tape it? I don't understand...
I use the boot that covers the pair. Just slide it over... It just needs to be protected from ground...
You could also use it for a kill switch..
Shikerwolf
I'm so confused (sorry I'm such noob)
What the crap is a the boot and what is the pair?!:mad2:
There is two wires, one directly from the block, another from a gold coloured box... A pair of wires...
A boot... In this case is exactly that, a cover for the wire connection... They are typically green coloured... To protect the connection from contacting ground...
Shikerwolf
so I'm supposed to somehow slide this boot over the wires?
ok pics/vids plz
Sorry Doug.... I know the pics are big....
The two wires seperated. The one from the box has a boot... If is already protecting the connector leave it... If not slide it over to what is shown...
no I've never taken it to anyone
I probably should get the engine checked out
there's a killswitch on the pics.. (toggle switch on the steering column)
have you tried starting the engine with that switch in BOTH toggle positions already?
I marked it in your image... see below
Shikerwolf
oh, sorry XD. This is my special build and that's not actually connected to the engine.
---------- Post added at 09:50 PM ---------- Previous post was at 09:48 PM ----------
ah, I get it. Thanks
Is that a high-tech string-operated throttle?
Nice Streaker.
I got one just like it but "The Rebel" decal didn't fare too well--'tis a shame too.
Here's one in better shape:
Shikerwolf
It will if there's no oil in the engine...
there is XD I change it a couple days ago
---------- Post added at 07:59 AM ---------- Previous post was at 07:55 AM ----------
Nice Streaker.
Yeah, mine is quite beat up! But the engine Is pretty new.
