Found the perfect welder! #4
jr dragster T
Cold place
That's pretty thin metel. Just under nearth your previa or the corolla and weld some stuff. Should be pretty thick:roflol: there.
ed1380
Banned
ATL, GA
what does the wire speed range go to? IIRC ours goes to 9 and we keep it around 3
oscaryu1
9 or 10 also... Heh, what do yall recommend? If I try n' do very thin metals? (AKA scrap recoils n' old sprockets)
ed1380
Banned
ATL, GA
might burn through if its under 1/16 or an inch
try something 1/8 and thicker. weld scratch pieces together.
oscaryu1
Hmm... 1/8"? That's... quite thick... I don't think I have many things that... thick. Should I go to Lowe's n' get 2 1/8" metal pieces?
oscaryu1
Eh... Oh, now that I remember, I have a dead mower engine (rod bolts stripped, n' rings are gone). So I have those parts... but I'd rather keep the mower deck, as it has that auto walking mechanism that works perfectly.
OH! I have the mower blade that came with it! Spring steel if I remember correctly... weld that to the side cover or something?
Kenny_McCormic
Kartless....
Michigan Troll
Snap the rod in half and weld it together. weld the cam to the crank.
oscaryu1
Lol. The rod bolt is stripped :(
I'll use my spare parts! Weld my ARC Billet rod back together, and my 94ss to my dual bearing .999 crank! :D Jk jk :p
But honestly... ?
oscaryu1
Oh dear... Ehh... It isn't broken lol...
I don't have a single broken rod... But I have around 5 Briggs 5HP rods, and 1 GX200 rod that I don't need...
jr dragster T
Cold place
No, when somone says "wall" they mean the thickness of the metel. for example 1 1/2 X .120 hat means the metel is hollow and it is 1 inch and a half wide and it is 1/8 thick.
