Found the perfect welder! #2
oscaryu1
We're aiming for #9 status :D
Anyhow, how should I test or know when I have gotten a good weld?
What should the knob be at (for the wirefeed thing)? Thanks again!
jr dragster T
Cold place
The wire feed is different for different thickness's of metel
And it is very precise. I have a lincoln electric MIG welder and some of the settings vary from 3 3/4 or 5 1/2 But your welder just has 2 heat settings. My lincoln has 10 heat settings and 10 wire feed settings:drool5: :2guns: after you learn to weld with flux core Maybe you can get into MIG. Once you ditch the flux core you will NEVER go back to it.
Kenny_McCormic
Kartless....
Michigan Troll
You can theoretically convert a flux core to mig with the bottle/reg and stuff found at a hardware store. just drill a hole in the tip/shield whatchamacarcass
stick some copper tubing in there (1/4" sounds about right, need around a foot (length of gun))
zip tie tube to gun
connect copper to 1/4" ID hose(need enough to run length of gun cable+3 feet)
zip tie tubing to cable
hook tube to reg
load proper wire
go welding
AutoMX
well when welding some decently thick metal, it's said that a half inch weld should be able to hold 500lb when pulled apart before breaking. not sure how useful that is to know. an easy way to check is to try to break the weld with whatever you got. if its supposed to hold you and you can break it with a hammer, the weld is no good.
also, the whole water thing is very questionable. putting hot metal in water is a way to harden the metal, especially if it was exposed to carbon like in coal. the harder a metal is, the more likely it is to crack under stress. if you're making drill bits, that fine, harder metal will last longer. if you're making a chassis or drivetrain/suspension components, you're gonna have parts that break under the stress of bumps and jumps.
so don't quickly cool down metal unless you need hardened metal for a specific reason. it also prevents warping the shape.
jr dragster T
Cold place
Here's some pics of my stuff. Excuse the mess in the garage/car.
kibble
I banned myself
What do most of yall have that wirefeed knob on?
There's not just one setting to have it on for all around use, it depends on what you're doing/trying to accomplish. You have to find a setting in that feeds the wire in just enough to not spatter all over the place. If it feeds too slow, you'll hear more like bzzz....bzzz.....bzzz....bzzz. You want a constant bzzzzzzzzzzzzzzzzz.
oscaryu1
Hmm... well we'll see. Next thursday, I'm bringing back a old one speed bike. What setting should I use?
On the helmet... there's also a knob on the side with numbers, and a slow-fast switch. What should these be on?
PS - This is a solar powered helmet, with 6V backup batteries...
Kenny_McCormic
Kartless....
Michigan Troll
Hmm... well we'll see. Next thursday, I'm bringing back a old one speed bike. What setting should I use? Trial and error/good guessing
On the helmet... there's also a knob on the side with numbers, and a slow-fast switch. What should these be on? Probably how quick it darkens and how dark it gets.
