Found the perfect welder! #2
oscaryu1
Where can I get a magnetic ground? And how long should I leave it before picking up the welded piece?
PS - Goin to HF to see what I can get today! :smartass:
kibble
I banned myself
HF has magnetic grounding devices. I had bought one when I got my welder... I just don't know where it is now. Hmmm... I gotta look for it.
Kenny_McCormic
Kartless....
Michigan Troll
Its got a pretty bad duty cycle on the high range but welding go cart frames from tubing you wont use the high range very often anyways. Should be fine for your purposes.
oscaryu1
So to break it down for me, what's the duty cycle I'll be doing? (Every 10 minutes)
And how long should I take on let's say a 1" weld?
ineed2fly
If you are brushing inbetween welds, and kinda just like working at a normal pace, you shouldnt need to take a break. Sounds like you had an expensive day!
oscaryu1
Yup! Tell me about it! WalMart, Sears, Harbor Freight, BestBuy...
Today me and my brother go paintballin! :D
Anywho, what do you mean "normal pace"? And again, how long should I spend on a weld? I don't wanna keep it there so long it melts everything to bits :p
oscaryu1
Thanks for the info! So... no jeans, Pan, duty cycle...
There's like an adjustment knob after the low/high switch... what's that for? Thanks Kenny!
AutoMX
the welder should have the wire feed speed (knob with speed #s), the high/low settings, and the on off switch.
welding with a wire feed or stick welder isnt like holding up a torch to metal and guessing when it's melted. you point, pull the trigger, and if you've welded it right the weld will be solid, if not, it will break when you pull. if you hover too long it will be painfully obvious, you'll have a giant ball of metal over the weld.
also, 'no jeans'? what then, naked? jeans are fine, unless you happen to have heavy duty raw leather pants (!?!) which would be ideal. welding in shorts is less desirable thought, burn potential (i'm almost used to it, red burn spots where metal beads burned through the pants/shirt) and UV blasting your legs which is no good.
jonesie8807
oscary - let me know how easy this welder is to use. i would like to learn how to weld. about how much did u spend for the whole set up?
oscaryu1
Around $160... $50 for the auto-dimming mask, and $120 for the welder. Oh, and a $20 warranty because my parents insisted on it :p
How long does it take for the metal to "solidify"?
crazycart
RedNek Engineering
MINNESOTA
A matter of seconds, i like to cool it down with some water also, just so it doesnt get too hot and burn a hole.
