flywheel?
kendelrk
redneck engineer
westland michigan
in my adventure to get the honda clone running again, i think the timing is bad, so i was trying to pull the flywheel to check, i put a long thing of twine down the spark plug hole to get the flywheel from turning, yet every time i turn the ratchet it breaks free, or it stays intact but wont turn at all, it goes to the point to where my uncle moved his arm out of place, any idea on how to get it off?:mad2:
karl
North east Ohio
You need a bigger rope. Try tapping the wrench with a hammer, it is like a impact wrench. Takes it right off. Funny thing- 1/2 an hour ago I pulled a flywheel off a 3hp briggs. Took me 10 min to clean the points and get it together.
karl
North east Ohio
Also, Dont pull the flywheel yet. Try a squirt of gas in the carb and check for spark. I highly doubt the timing is your problem.
kendelrk
redneck engineer
westland michigan
tryed a squirt of it in the carb nothing, i checked spark, bright blue and crisp, and tryed just a little in the head to see if it was fuel delivery and with both, not even a backfire choke and no choke, no run, not anything, and ive tried with not only a hammer, but also my foot, and it always turns
karl
North east Ohio
Turn the engine to top dead center and see if the magnet lines up. Does it have good compression? But if you wanna tear of the flywheel you need a rope with a descent diameter
karl
North east Ohio
I have never been not able to remove a flywheel nut. Even on engines from the 70s that sat outside for years. You must be messing up somewhere if you cant get it off a newer engine.
kendelrk
redneck engineer
westland michigan
i just got upset and pulled out the air compressor and impact gun and let that ***** do it, so well i was at it i took off the flywheel, flywheel cover and the gas tank because im going to get the orignial one, so it looks better, matt can you get on aim? and here are the pics of the bike itself and under the flywheel fan, not exactley sure of the flywheel key or if you can see it, because im a noob at this part
r_chez_08
Should be in the shop...
Cornwall, UK
From what i can see that doesnt look good. Wind the nut on a few turns onto the crank and smack the nut with a hammer. DO NOT HIT THE FLYWHEEL!!!
that should get it off, so you can check the key.
Rob
Never mind the pic. If it fills the slot in the crank and the slot in the flywheel, it's fine. Note that many engines use a half round key, which should be flat on one side.
kendelrk
redneck engineer
westland michigan
****, the green wire coming form the coil, it comes through the kill switch but dont know where the other end goes, it came out, wtf
