flywheel?
Bluethunder3320
how the he11 did you manage to break a plug like that? i have never seen that, ever!
good thing it runs. check this plug (w/o breaking it lol) soon, and make sure its not building up carbon like the last.
looks like it was running rich to me, or you had a very old plug.....
kendelrk
redneck engineer
westland michigan
ive been running that plud since i got it so about a year and a half, and i will, it might be because i um, well i was using one just one hair to big to get it off and boom white casing everywhere, and i was like WTF so i got a new one and i ahd the idle high pulled it twice third time it started and **** near killed me, it took the **** off
kendelrk
redneck engineer
westland michigan
hell i was to lasy, it was because i had the idle screw into far from last tests, i had it under control tho, it was on choke lol
Badot
Usually plugs will break like that when you put too much sideways force on them trying to take them off (as opposed to torque)... usually happens when people are using extenders and/or not bracing the head of the ratchet while torquing it.
kendelrk
redneck engineer
westland michigan
well, i did a bit of working to hook it up, well gas was leaking out of the sediment bowl and main jet but that was whatever right now, so i tried again after it wouldnt start with a bit of gas in the head and again it **** near takes off with the idle screw all the way down ????? and now when i pull the recoil, it squeks?
It's official- You DO have the worst luck with your engine of anyone I have ever heard of.
Offhand, I would humbly suggest you work slowly and carefully- referring to the manual frequently, taking notes, making only one change at a time, and using the right tools.
kendelrk
redneck engineer
westland michigan
oh ive screamed at it, called it some names, gave it the cold shoulder yeah ive done it all, with the words and all, but i didnt break parts
Bluethunder3320
if you have money for the performance carb, by all means use it.... not sure how you can hook it up to the governor..... best bet would be to pull it.
Bluethunder3320
well if the carb is spilling gas out its obviously a carb problem.
maybe bad needle seat, or a gasket somewhere.
kendelrk
redneck engineer
westland michigan
Well either it's that or just realizing. The hose was a Lot looser than the other so Mayr it was just dripping from the hose and coming off the carb I'll check, and I'm getting closer
