Thanks for showing me a way to waste ~4 hrs time, Paul;
LOL. I have also spent a few hours on that thread.
This is still going on? I haven't been on in a few days.. lol
I plan on uploading some more pics tomorrow on my steering
I DEFINATELY can't wait
I guess you can call it a form of ackermann. A PVC pipe keeps the tires syncronized when being turned.
Those two sentences contradict each other: If the wheels are synchronised, you don't have ackermann. Ackermann means the inside wheel turns on a greater angle than the outside wheel.
If you look at pic 3, you will see that the right/outside wheel is turned at a greater angle than the left/inside wheel; you want the opposite of that...
Just finished my custom steering setup. I guess you can call it a form of ackermann. A PVC pipe keeps the tires syncronized when being turned.
I also changed up the hinge mounting, and the new version seems stronger and eliminated the turning radius problem.
After a bunch of trial and error here is the final outcome. Steering wheel is next.
when talking to you about safety.....
So where are we supposed to send the flowers? Using PVC for your tierod is like replacing your certified parachute with a plastic drop cloth from the hardware store when you go skydiving. If you insist on using some form of pipe for parts, step up to black pipe; that actually has structural properties. 1/2" threaded rod would be a good choice as well, plus you would have a chance of being able to attach whatever steering you come up with.:toetap05: It feels like I'm beating awhen talking to you about safety.....
there is no question... PVC is not strong enough....
This is stupid. You are stupid. Maybe you should try gluing some macaroni to a piece of paper before you try to make a machine. Seriously. You ignore everyone in this thread so you will probably ignore this post too.
Put down the screwdriver or stab yourself in the eye with it. Whatever....
Woah now instead of just splinters of wood you can dig out chunks of PVC too!!
I'm just bustin ya. PVC can be pretty strong. Ive built a few bows and an air cannon. But structural its not the best choice
