Finds in the SW PA area
migel101
south america
when searching places like that, (craigslist, ebay, etc) search not only obvious things like; kart, gokart, go kart, etc, but also common misspellings, mislabelings or typos: gocarts, sand buggy, etc.
redsox985
PA
http://pittsburgh.craigslist.org/mcy/2556875795.html
So tell me, what are your search terms you use?
Gocart, go cart, gokart, go kart, buggy, buggie, fl250, fl 250, fl350, and fl 350. I think that's about it.
EDIT: Oh and "odyssey" then restrict the price between 100 and 5000. It seems like a big range, but it rules out most of the vans which are EVERYWHERE around here.
At least on CL, go kart and go cart will return any ad containing kart or cart, so you don't need to search them separately. When searching go cart, I get volumes of microwave carts.
redsox985
PA
bighead
Pacific Northwest USA
I'm looking into this. It's got a KT100 all mounted up but probably just needs some cleaning if all it does is bog under throttle.
http://pittsburgh.craigslist.org/rvs/2760730819.html
And this just looks insane. Dual KT100's.
http://pittsburgh.craigslist.org/rvs/2753934204.html
Da**. This is nice. Two FL350s.
http://pittsburgh.craigslist.org/rvs/2753684399.html
http://pittsburgh.craigslist.org/mcy/2719164624.html
$1800 is a very good price for an fl350. I see most from $2000 to $3000 running or little work in that condition (if you can find them local) If you walk away with it for $1600 you stole it. Parts are dime a dozen outside the trans,engine and plastic. It's the kart that will last forever and only go up in value. The Ody's are killer. Clean fl350's go close to $4000 up. The fl400 even higher.
Plastics are $500 plus so always figure that into when buying the FL350.
redsox985
PA
If I had space, I would be all over that cheaper FL350. I wonder what they mean by it's been fixed? If it looks decent or is it drilled and zip tied together.
The only problem is the it's about an hour and a half away and I have no means of getting it home. I'm interested in that first KT100 kart though. :) What would you say it's worth?
