epa tube on briggs
acg23
bay area
i just put it back together how it was not worth it.
i have a new problem.. when i start it, it idels very hard.. also it is smoking out the tail pipe... i dnt see why this happend out of nowhere.. the other day it was running like a champ.. any suggestions?
acg23
bay area
yes it was.. i was drilling the side to mount the kickstand.. not compleatly sideways but was tipped. the oil level is to the bottom of the cap. how do i fix this?
Blazkowiez
Kart Aficionado
Houston, Texas
Why has nobody mentioned that the older briggs just had the hose dumping down out the valve cover there... that has to stay open but you can plug the hole on the carb like you've already got. This is amazingly common...
acg23
bay area
alright.. i didnt think it was too big of a deal.. how do you make the engine run better after it has been tippd tho?
acg23
bay area
should i take off the head and clean out the oil on it? or will it just burn off after time?
solomon
ca
I would take the spark plug out and pour some gas in their to dilute it, then after 10 minutes pull it over 9 or 10 times, reinstall the plug and let the motor burn off the rest.
freakboy
the names 'mater
hick town
Just run it normally until it clears. Nothing special to do.
exactly what russ said... if you get more oil in the cylinder head from the engine being tiped its not like you ruined it or you have to dissasemble it for it to run right or what not....
acg23
bay area
ive noticed some oil coming out one of the head bolts. also oil came out of the gasket. will this cause it not to idle?
acg23
bay area
i ran it for 10 minutes nd it is still running the same. nd even after it has warmed up still will not idle. is this the signs of bad head gasket?
acg23
bay area
it is on the side by the fly wheel. hard to tell. can an engine still run with a blown gasket?
solomon
ca
Do a compression check. Might have worn rings, but sounds like oil drenched everything.
acg23
bay area
i took the head off nd there was alot of oil on the top of the piston. also there was oil on the outside of the fins behind the fly wheel. i will be getting a new head gasket tommoro. hopefully this will solve my problem.
